    Python Generator and texte
    pythonr25
    3 Posts 2 Posters 633 Views 1 Watching
    • B Offline
      bureaudesprojets
      Hello there,
      for the plugin i'm working on, I need to generate an aeronautical numerotations. Meaning it goes like A, B , C... Z, AA, AB , AC
      I made a code wich I fill with the number of letters I want and the distance I want between each letters.
          number= op [c4d.ID_USERDATA,3]
          distance = op [c4d.ID_USERDATA,4]
          alphabet=["A","B","C","D","E","F","G","H","I","J","K","L","M","N","O","P","Q","R","S","T","U","V","W","X","Y","Z"] ;
          for x in range( number):
              if ((x//26)-1==-1) :
                  null = c4d.BaseObject ( c4d.Onull)
                  texte = c4d.BaseObject(1019268)
                  texte[c4d.PRIM_TEXT_TEXT]= alphabet [x]
                  print (alphabet [x])
                  texte.InsertUnder ( null)
              else :
                  texte[c4d.PRIM_TEXT_TEXT]= alphabet [(x//26 - 1)]; alphabet [x%26]
                  print (alphabet [x//26 - 1], alphabet [x%26])
          texte[c4d.ID_BASEOBJECT_REL_POSITION,c4d.VECTOR_Z] = x* distance
          return null
      This is the result of my programs. I have the right letters but it display only the letters corrrespodings to the number not all letter before. Like in the picture above.
      I hope my issue is clear
      Thanks a lot
      Nadja
        ferdinand @bureaudesprojets
        Hello @bureaudesprojets,
        welcome to the Plugin Café and thank you for reaching out to us. That looks like a fun project you have there.
        However, there are a few problems with your code.
        You redefine your null on each step of the loop, causing only the last iteration to be returned. It is:
        if ((x // 26)-1 == -1):
           null = c4d.BaseObject(c4d.Onull)
           texte.InsertUnder(null)
        But it should be:
        This was what caused your major problem, but there were also other problems with how you set the distance between the elements with texte[c4d.ID_BASEOBJECT_REL_POSITION,c4d.VECTOR_Z] = x* distance, which was outside of the loop, and I also did not understand the whole "aeronautical numerations" thing in your code.
        Find below an example of how I would do it.
        The result:
        The file:
        abcd.c4d
        The code:
        """Simple example for building caches for a Python Generator object.
        import itertools
        # The upper case letters from their ASCII range.
        ALPHABET = tuple(chr (i) for i in range(65, 91))
        def GetNumerationList(a: int, b: int) -> list[str]:
            """Returns a list of numerations following your scheme from index #a
            to #b.
            # I have no clue what aeronautical numerations are, but I guess
            # you just want A-Z, AA-AZ, BA-BZ, ..., ZA-ZZ, AAA - AAZ, and so on.
            # I do not really see how your code was supposed to do that. I did
            # provide below a simple version using itertools.
            assert(a < b)
            # Build the full array, we could also be more elegant here, and only
            # build what we need, but that would be up to you. I create here quite
            # a lot of entries to avoid index errors. range(1, 4) means we create
            # everything from A to ZZZ, i.e., 26 + 26² + 26³ ~ 18,000 items. Python's
            # iteration is slow, and you should optimize this.
            result = []
            for i in range(1, 4):
                result += ("".join(item)
                           for item in itertools.product(ALPHABET, repeat=i))
            # And return the slice we have been asked for.
            return result[a:b]
            """Executed by Cinema 4D to build the cache of the Python Generator.
            # Instantiate a null object to parent the "numerations" to.
            if not isinstance(null, c4d.BaseObject):
                raise MemoryError()
            # Get the user data.
            a = op[c4d.ID_USERDATA, 1] # The starting index.
            b = op[c4d.ID_USERDATA, 2] # The end index.
            distance = op[c4d.ID_USERDATA, 3] # The distance between elements.
            # Iterate over all numerations between the index #a and #b.
            for i, item in enumerate(GetNumerationList(a, b)):
                # Instantiate a text object.
                node = c4d.BaseObject(1019268)
                if not isinstance(node, c4d.BaseObject):
                    raise MemoryError("Could not allocate object.")
                # Set the text to the yielded numeration item.
                node[c4d.PRIM_TEXT_TEXT] = item
                # Set the distance on the x-axis in the local space of the parent,
                # the null object.
                node.SetMl(c4d.Matrix(off=c4d.Vector(i * distance, 0, 0)))
                # Parent the text object to the null object.
                node.InsertUnder(null)
            # Return the cache.
            return null
        • B Offline
          bureaudesprojets
          Thanks a lot for your help !
