    Changing VideoPost leads to TypeError
    r25windowspython
    4 Posts 2 Posters 536 Views 2 Watching
    • ? Offline
      A Former User
      I am trying to change the Viewport Renderer parameters. I was able to use the method illustrated in the code sample below, but something changed (I believe in the API) and this now leads to TypeError: __setitem__ expected str, not bool. If I'm not to assign these values as a boolean, can someone please advise on how these are to be set? Thank you.
      from c4d import documents
          rdata = doc.GetActiveRenderData()
          rd = rdata.GetData()
          post = rdata.GetFirstVideoPost()
          post[c4d.VP_PREVIEWHARDWARE_DISPLAYFILTER_NGONLINES] = False
          post[c4d.VP_PREVIEWHARDWARE_DISPLAYFILTER_OTHER] = False
          post[c4d.VP_PREVIEWHARDWARE_DISPLAYFILTER_SDSCAGE] = False
          post[c4d.VP_PREVIEWHARDWARE_DISPLAYFILTER_ONION] = False
      • ? Offline
        A Former User
        I think I have discovered the issue: I believe rdata.GetFirstVideoPost() was getting a renderer other than the Viewport Renderer, so those symbols weren't available. I am now using the following (I found it here) to check that the video post is the Viewport Renderer.
                    while post is not None:
                      if post.CheckType(300001061):
                        break
                      post = post.GetNext()
                    if post is None:
                      rd.InsertVideoPost(c4d.BaseList2D(300001061))
        Unless the API devs have any corrections, I'll mark this as solved.
          Pretty strange i was not able to reproduce the issue.
          @blastframe said in Changing VideoPost leads to TypeError:
          300001061
          you can use the symbol c4d.RDATA_RENDERENGINE_PREVIEWHARDWARE instead.
          • ? Offline
            A Former User @Manuel
            @m_magalhaes Yes, I think the error was because Octane was the result of rdata.GetFirstVideoPost() and those symbols don't exist in it. If I check for the Viewport Renderer, it seems to work fine. Thanks for the reply and symbol tip!
