    Loading Materials from AssetDescriptions into a Scene
    c++r25
    3 Posts 2 Posters 973 Views 1 Watching
    • K Offline
      krfft
      Thanks for the help @ferdinand, the plugin rewrite from python is coming along nicely and I am able to fetch all AssetDescription* from the Asset API.
      However reading the handbook I am unable to find a way to fetch a BaseMaterial* from the AssetDescription*. Are you able to guide me towards a solution? I need this to be able to create a Take with a specific material.
        ferdinand @krfft
        Hello @krfft,
        thank you for reaching out to us. I did fork your question because it was a new question.
        About your question: This part of the Asset API has unfortunately not been documented yet. Neither in form of a handbook or examples provided by us, nor in form of doc-strings provided by our developers. We plan to update the handbook soon, but what you must do in principle is use AssetCreationInterface and there the function CreateMaterialsOnDrag. Which was named a bit weirdly (at least from an SDK user point of view) and should be more interpreted as LoadMaterialAssetIntoDocument. You could technically also use the maxon::Url of a material asset to load in the asset document manually via LoadDocument, but you would then have to unpack some of the material data yourself.
        I will post an example in the next days, but I do not have the time to do it today.
          Hello @krfft,
          here the promised code. It is an extension of the Search Assets example which can be found in the Asset API Handbook.
          I hope this helps and cheers,
          The result:
          The code:
          static Int32 g_max_materials = 10;
          /// Loads in the first ten material assets into the active document which can be found in the user
          /// prefs repository.
          /// I did remove most of the comment fluff here, assuming you are already familiar with the rest.
          maxon::Result<void> LoadAssets()
            iferr_scope;
            // Get the active document and do some setup stuff to search for all materials in the user prefs
            // repository. See FindAssets() example function in the Assets API exmaples for details.
            if (doc == nullptr)
              return maxon::UnexpectedError(MAXON_SOURCE_LOCATION, "No active document."_s);
            const maxon::AssetRepositoryRef& repository = maxon::AssetInterface::GetUserPrefsRepository();
            const maxon::AssetType assetType = maxon::AssetTypes::File();
            const maxon::Id assetFindId = {};
            const maxon::Id assetVersion = {};
            maxon::BaseArray<maxon::AssetDescription> results;
            repository.FindAssets(
              assetType, assetFindId, assetVersion, maxon::ASSET_FIND_MODE::LATEST, results) iferr_return;
            // Iterate over the results until we have found ten materials.
            maxon::Int counter = 0;
            for (maxon::AssetDescription assetDescription : results)
              if (counter == g_max_materials)
                break;
              maxon::AssetMetaData metadata = assetDescription.GetMetaData();
              maxon::Id subTypeId = metadata.Get(maxon::ASSETMETADATA::SubType) iferr_return;
              // This is a material asset.
              if (subTypeId == maxon::ASSETMETADATA::SubType_ENUM_Material)
                // With a valid url.
                maxon::Url url = assetDescription.GetUrl() iferr_return;
                if (url.IsEmpty())
                  continue;
                // The url of the asset is in case of material assets a c4d file. So, we  merge that asset
                // document with the active document.
                ApplicationOutput("@| Type: @, Url: @", counter, subTypeId, url);
                maxon::String* error = {};
                maxon::Bool didMerge = MergeDocument(
                  doc, MaxonConvert(url), SCENEFILTER::MATERIALS, nullptr, error);
                ApplicationOutput("@: Merged: @,  Error: @", counter, didMerge, error);
                if (didMerge)
                  counter++;
            return maxon::OK;
