    Python "undo" changes the original selection order
    6 Posts 3 Posters 1.6k Views 3 Watching
    • R Offline
      reubenlara
      Hello! My script relies on selection order and works fine. however, when I undo and run the script again immediately, the selection order is changed (somewhat reversed), and it toggles the reversal consistently. Why is it doing this? And is there a way to make sure the selection order stays constant when re-invoking the script?
      You can see a clearer explanation of my problem:
      in this brief screen recording
      from c4d import gui
          doc.StartUndo()
          selected = doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_SELECTIONORDER)
          #print order of object names to console
          print ("start:")
          names = []
          for obj in selected:
              names.append(obj.GetName())
          print (names)
          #distribute objects
          for idx, ob in enumerate(selected):
              doc.AddUndo(c4d.UNDOTYPE_CHANGE, ob)
              print (ob.GetName())
              ob[c4d.ID_BASEOBJECT_GLOBAL_POSITION,c4d.VECTOR_X] = 0
              ob[c4d.ID_BASEOBJECT_GLOBAL_POSITION,c4d.VECTOR_Y] = 0
              ob[c4d.ID_BASEOBJECT_GLOBAL_POSITION,c4d.VECTOR_Z] = 0 + (idx * 1000)
          doc.EndUndo()
        I've open a bug report for this.
        R 1 Reply Last reply Reply Quote 1
        • R Offline
          reubenlara @Manuel
          @m_magalhaes Excellent thank you! Will you post the results here? Or is there a another link I should follow?
            well, first it needs to be fixed, then release on a cinema4D's update (hotfix, service pack, release)
            R 1 Reply Last reply Reply Quote 0
            • R Offline
              reubenlara @Manuel
              @m_magalhaes ah ok thanks for the clarification. So, at this point, you can confirm that this is a bug and not a mistake in implementation on my part?
                yes exact, it's a bug not an error from your implementation.
                • maxonM maxon moved this topic from Cinema 4D SDK on
