    Python Script to Export multiple GLTF files (glTF Exporter Unexpected Error)
    3 Posts 2 Posters 798 Views 1 Watching
    • J Offline
      johntravolski
      I want to change the value of a parameter and then export a .gltf file in C4D R23, and do this over and over again for many values. I'm trying to do it with this code, but it is not working:
      from c4d import documents, plugins
      import c4d.documents as docs
          for ii in range(882):
              obj = doc.SearchObject("Selector")
              obj[c4d.ID_USERDATA,1] = ii
              docs.SaveDocument(c4d.documents.GetActiveDocument(), f'out{ii}.gltf', c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST, format=c4d.FORMAT_GLTFEXPORT)
      Unfortunately, I get this error:
      How do I fix this? I think I need to specify the gltf export settings somehow, but I don't know how to do this.
        please for you next post, follow our guildelines, using the forum function to mark your thread as a question or solve once it's done help us a lot. Also, tags can help us to faster reproduce the issue.
        we got an example on github about exporting obj. I've adapte the code to export gltf
        And please don't ask the question on different forum, otherwise you will waste people time.
        In your case, you are changing a userdata value. Using c4d.EventAdd() in a loop will (may not) update cinema4D on each loop. c4d.EventAdd() just push an event on a stack.
        Instead, you may want to use ExecutePasses. This will update the scene without updating the editor. On some specific case, you must call it twice in a row to be sure the scene is updated.
            # Retrieves a path to save the exported file
            filePath = c4d.storage.LoadDialog(title="Save File for OBJ Export", flags=c4d.FILESELECT_SAVE, force_suffix="gltf")
            if not filePath:
            print (filePath)
            # Retrieves glft export plugin.
            objExportId = c4d.FORMAT_GLTFEXPORT
            plug = c4d.plugins.FindPlugin(objExportId, c4d.PLUGINTYPE_SCENESAVER)
            if plug is None:
                raise RuntimeError("Failed to retrieve the gltf exporter.")
            data = dict()
            # Sends MSG_RETRIEVEPRIVATEDATA to gltf export plugin
            if not plug.Message(c4d.MSG_RETRIEVEPRIVATEDATA, data):
                raise RuntimeError("Failed to retrieve private data.")
            # BaseList2D object stored in "imexporter" key hold the settings
            objExport = data.get("imexporter", None)
            if objExport is None:
                raise RuntimeError("Failed to retrieve BaseContainer private data.")
            # Defines gltf export settings
            objExport[c4d.GLTFEXPORTER_UNITSCALE] = 2.0
            objExport[c4d.GLTFEXPORTER_CURRENTFRAME] = True
            # Finally export the document
            if not c4d.documents.SaveDocument(doc, filePath, c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST, objExportId):
                raise RuntimeError("Failed to save the document.")
            print("Document successfully exported to:", filePath)
        • J Offline
          johntravolski @Manuel
          @m_magalhaes This worked great, thank you.
