    interactions between two or more plugins which are in a single Python file
    8 Posts 3 Posters 1.5k Views 1 Watching
    • L Offline
      Ling
      how can I make interactions between two or more plugins which are created in a single Python file, including the commandData plugin and the toolData plugin. now, I want to send a message from a toolData plugin to two or more commandData plugins if the 'if' conditions is Ture. but, I don't want to use global values in Python. How can I realize that. Thank guys!
      • C4DSC Offline
        C4DS
        https://developers.maxon.net/forum/topic/11436/send-message-to-tooldata
        https://developers.maxon.net/forum/topic/13379/send-message-to-commanddata
        L 1 Reply Last reply Reply Quote 1
        • L Offline
          Ling @C4DS
          @c4ds I had got a try.
          I write codes:
          commandPlugin=c4d.plugins.FindPllugin(the plugin id, c4d.PLUGINTYPE_ANY)
          commandPlugin.Message(the integer)
           in GetCursorInfo() called back function of toolData.
          and, codes:
          if type== the integer:
             print(the integer)
          in Message() called back function of commandData.
          but the codes can't print "the integer" when I move the mouse with the toolData.
          actually, I change codes like that:
          print(the integer)
          in Message() called back function of commandData. .
          but I still can not receive a message.
          I want to change a value or execute a function in the commandData baesd on the mouse movement of toolData or a message from toolData
          • C4DSC Offline
            C4DS @Ling
            @Ling
            You cannot simply call Message(the integer) on a CommandData.
            As I mentioned in the link (https://developers.maxon.net/forum/topic/13379/send-message-to-commanddata) the CommandData expects a message of type MSG_COMMAND. You cannot pass any integer.
            But since you want to send more information than just an integer you then cannot use the solution I provided by using the CommandData.ExecuteSubID.
            Note that a CommandData is more like a "single-shot" action. It would probably be a better idea to look for something else to "change a value" than a CommandData.
            Without knowing the whole idea behind your plugin it is hard to suggest something.
            L 1 Reply Last reply Reply Quote 0
            • L Offline
              Ling @C4DS
              @c4ds Thanks! I had changed my solution. Thank you to reply me!
              • C4DSC Offline
                C4DS @Ling
                @ling said in interactions between two or more plugins which are in a single Python file:
                If you could share the solution, or at least the concept behind it, this might help others with a similar problem looking for a solution.
                • L Offline
                  Ling
                  I just use 'global value' to settle this problem. it is not good way or good solution for coding. but I have to solve this problem in a short time because it is just a little part of my plugin. I have so many problems to deal with that I can not waste my time.I think the message of commandData will update or call back when this command gui updates, or message maybe update with other conditions.sorry! I just a newbie for programming.
                    I'm happy that you solved your issue.
                    For your next post, and i know you can see that as a waste of time, please follow our guidelines. Use the functionalities of the forum to mark your thread as a question, and mark it as solved when it's done. (Even for a negative answer).
                    Please use also tags, that help us to understand and answer faster without guessing. Language you are using (python, c++) cinema4D version, everything that can help us to understand your issue.
                    You will also find on those guidelines how to explain your issue. Sometimes people want a solution for an issue creating by a bad workflow.
                    In your case, it looks more like sharing information between plugins. There are several answers/possibilities for that.
                    This forum is also about stepping back, having a fresh eye on your issue and move forward 🙂
