    Xpresso set port for all nodes
    3 Posts 2 Posters 874 Views 1 Watching
    • ROMANR Offline
      ROMAN
      Hello for everyone. Is it real to set up parameters like a position and rotation for all selected nodes by python?
          nodes = []
          root = nodeMaster.GetRoot()
          for node in root.GetChildren():
              if node.GetBit(c4d.BIT_ACTIVE):
              ##place for setting parameter##
      If its real, could you write a command which set up x position in input for example
        first i would like to point you to our guidelines. You will read there how to mark your thread as a question and how to use tags.
        You got some example in our github repository that could help. The first one will show you how to iterate nodes and go inside groups if any. The second is to create and connect nodes. Once you got your node, you must use the function AddPort
        You have to define the direction (output or input) and use the right ID
            child.AddPort(c4d.GV_PORT_OUTPUT, c4d.ID_BASEOBJECT_REL_POSITION )
            child.AddPort(c4d.GV_PORT_OUTPUT, [c4d.ID_BASEOBJECT_REL_POSITION,c4d.VECTOR_X] )
        Don't forget you can use drag and drop on the python console to retrieve the IDs, more information on this page
        ROMANR 1 Reply Last reply Reply Quote 1
        • ROMANR Offline
          ROMAN @Manuel
          @m_magalhaes Thank you for answer!
