    Hide "Camera Dependent" from PriorityData
    3 Posts 2 Posters 834 Views 1 Watching
    • orestiskonO Offline
      orestiskon
      I'm making a plugin object with Priority options and have a couple of questions about PriorityData.
      1. How can we hide the "Camera Dependent" option? I tried guessing the flag unsuccessfully. 😕
        Example objects without "Camera Dependent" option are the Hair object and the Skin deformer.
      2. How can we set the default value for such a parameter? I tried using the following code in the Init function but didn't work:
      basePriority = c4d.PriorityData()
      priority.SetPriorityValue(c4d.PRIORITYVALUE_MODE, c4d.CYCLE_EXPRESSION)
      priority.SetPriorityValue(c4d.PRIORITYVALUE_PRIORITY, 400)
      node[res.BASE_PRIORITY] = priority
      Thanks for any assistance
        Hi @orestiskon this can be done with the NOCAMERA option, see PRIORITY.
        PRIORITY TEST_PRIORITY_VALUE {NOCAMERA;};
        And in my case I did set within the Init the next code and it's working as expected.
                priority = c4d.PriorityData()
                priority.SetPriorityValue(c4d.PRIORITYVALUE_PRIORITY, 200)
                node[TEST_PRIORITY_VALUE] = priority
        The only difference with your code is that you are using priority but you created basePriority, I guess it's a copy error but if not, then I would need your entire code since I can't reproduce your issue.
          orestiskon
          Thanks Maxime,
          "NOCAMERA;" worked, and the priority was a typo, now it does work!
