    Iterate through selected Materials
    3 Posts 2 Posters 729 Views 2 Watching
      moko
      Is it possible to make an iteration through a selection of Materials.
      I'd like to rename the texture after the material. It works but only on all materials in the doc. how do i specify it on to a selection of materials?
      from c4d import gui
      from c4d import storage
      import  os
      def changeTexture(shader):
          # shader ID
          texturePath = shader[c4d.BITMAPSHADER_FILENAME]
          # split aboslute path
          oldTexturename = os.path.split(texturePath)
          fileExtension = os.path.splitext(texturePath)
          # add prefix to
          newTexturename = matName + fileExtension[1]
          print (newTexturename)
          newTexturePath = os.path.join(oldTexturename[0], newTexturename)
          print (newTexturePath)
          # rename texture
          try :
              os.rename(texturePath, newTexturePath)
              print("Source path renamed to destination path successfully.")
          except OSError as error:
              print(error)
          # Assign the new value
          shader[c4d.BITMAPSHADER_FILENAME] = newTexturePath
          shader.Message(c4d.MSG_UPDATE)
      # Main function
          c4d.CallCommand(1029486) # Project Asset Inspector...
          c4d.CallCommand(1029813) # Select All
          c4d.CallCommand(1029820) # Globalize Filenames
          # Iterate over selected material
          mat = doc.GetFirstMaterial()
          while mat:
              shader = mat.GetFirstShader()
              global matName
              matName = mat.GetName()
              while shader:
              # Test if the current node is a bitmap shader.
                  if shader.CheckType(c4d.Xbitmap) :
                  shader (shader.GetDown())
                  shader = shader.GetNext()
              mat = mat.GetNext()
          # c4d.CallCommand(200000273) # Reload All Textures
      # Execute main()
        ferdinand @moko
        Hello @moko,
        thank you for reaching out to us. There are in principle two ways to do this. BaseDocument contains a handful of methods to retrieve the 'active', i.e., selected, entities of some type, e.g., objects, tags, and also materials. The method in question would be BaseDocument.GetActiveMaterials().
        There is also a more general-purpose approach via BaseList2D.GetBit() for retrieving the selection state of a node, which will also work for node types that that do not have such special purpose methods. For details, please see the example at the end of this posting.
        """Example for determining the selection state of BaseList2D nodes via GetBit().
        To be run as a Script Manger script. Will print out the names of the selected
        materials.
        As discussed in:
            https://developers.maxon.net/forum/topic/13446/
            # We can get the active Materials with BaseDocument.GetActiveMaterials()
            for activeMaterial in doc.GetActiveMaterials():
                print (f"{activeMaterial.GetName()} is a selected Material.")
            print ("\n", "-" * 100, "\n")
            # Or we can iterate over the materials and use the bit flags of the nodes
            # to determine their selection state. The advantage here is that this will
            # work for any BaseList2D and not only the ones (objects, tags, materials,
            # etc.) where specific methods exist to retrieve the selected/active ones.
            # The relevant method is BaseList2D.GetBit() and the relevant bit mask is
            # BIT_ACTIVE - which indicates the selection state of the BaseList2D.
            # Get the first material like you did.
            material = doc.GetFirstMaterial()
            if not material:
            while material:
                # Print out only materials that are selected.
                if material.GetBit(c4d.BIT_ACTIVE):
                    print (f"{material.GetName()} is a selected Material.")
                material = material.GetNext()
        # Execute main()
          moko @ferdinand
          Thank you very much! The second way works great. I didnt get the first approach to work, but the second does well 🙂
          Here is the script if someone needs it. It is probably messy I am not a programmer, but it does write the names of the selected materials into the texturname
          from c4d import gui
          import  os
              # shader ID
              # add prefix to
              # rename texture
              try :
                  print(error)
          # Main function
              c4d.CallCommand(1029816) # Select Assets of Active Elements
              if not material:
              while material:
                      shader = material.GetFirstShader()
                      global matName
                      matName = material.GetName()
                      while shader:
          # Execute main()
