    Help needed with sketch material
    4 Posts 3 Posters 988 Views 1 Watching
    • I Offline
      InterfaceGuy
      I need help with the sketch material
      If I want to create and apply a regular material to, say, a cube I am fine using the code below:
      mat = c4d.BaseMaterial(c4d.Mmaterial)  # material
      tag = c4d.BaseTag(c4d.Ttexture)  # tag
      tag.SetMaterial(mat)  # assign material to tag
      obj = c4d.BaseObject(c4d.Ocube)  # create cube
      doc.InsertObject(obj)  # insert cube
      doc.InsertMaterial(mat)  # insert material
      obj.InsertTag(tag)  # apply tag to material
      Now if I want to do the same thing with the sketch material with the analogous code:
      c4d.Msketch = 1011014  # add missing descriptor for sketch material
      c4d.Tsketch = 1011012  # add missing descriptor for sketch tag
      mat = c4d.BaseMaterial(c4d.Msketch)  # material
      tag = c4d.BaseTag(c4d.Tsketch)  # tag
      I get the error message:
      AttributeError: 'c4d.BaseTag' object has no attribute 'SetMaterial'
      I obtained the missing descriptors from the script log, but the sketch tag and material seem to behave differently than regular materials in this regard.
      Help would be greatly appreciated!
      • CairynC Offline
        Cairyn
        1011012 is the sketch style tag which is not a subclass of the TextureTag class.
        To assign a sketch material to an object, you use the c4d.Ttexture ID as well, like in your previous example.
        If you want to do something with an actual sketch style tag, you can use the square bracket notation, like
        SketchStyle[c4d.OUTLINEMAT_LINE_DEFAULT_MAT_V]
        for the Default Visible material.
          Nothing to add, thanks @Cairyn for the answer 🙂
          • I Offline
            InterfaceGuy
            It worked!
            Thank you so much!
