    How to create a material with the selected object as assigned?
    r20python
    4 Posts 2 Posters 998 Views 1 Watching
    • JH23J Offline
      JH23
      I tried to make a script where when generating a material, assign the active object that material but I do not know if it should go the way I am doing it or it is wrong, I also saw in the script history c4d.ID_MATERIALASSIGNMENTS
      I guess it has something to do with it but I don't understand
      mi codigo
      from c4d import gui
          cubo = doc.GetActiveObject()
          c4d.CallCommand(13015, 13015) # Nuevo Material
          mat = doc.GetAciveMaterial()
          mat[c4d.MATERIAL_PAGE_ASSIGNMENT] = cubo
        ferdinand @JH23
        Hello @JH23,
        thank you for reaching out to us. While it is possible to use CallCommand in scripts for the more basic things like creating a material, it is recommended to use the more abstract object-oriented API whenever possible. Below you will find an example script which creates, modifies and assigns a new material to the currently active object.
        """Example for creating a material and assigning it to the currently active
        object.
        As discussed in:
            https://developers.maxon.net/forum/topic/13357
            # op and doc a are module attributes predefined by Cinema 4D for a script
            # module. doc is the currently active document, op the currently active
            # object in this active document.
            if op is None:
                raise RuntimeError("Please select an object.")
            # Instantiate a standard material and insert it into the document, as
            # otherwise we could not use it.
            mat = c4d.BaseList2D(c4d.Mmaterial)
            doc.InsertMaterial(mat)
            # Example for modifying the material, here setting its diffuse color.
            mat[c4d.MATERIAL_COLOR_COLOR] = c4d.Vector(1, 0, 0)
            # Create a texture tag on the selected object, change the projection mode
            # to uvw and link the newly crated material to it.
            tag = op.MakeTag(c4d.Ttexture)
            tag[c4d.TEXTURETAG_PROJECTION] = c4d.TEXTURETAG_PROJECTION_UVW
            tag[c4d.TEXTURETAG_MATERIAL] = mat
            # Notify Cinema 4D of the changes made.
        # Execute main()
        • JH23J Offline
          JH23
          Hello @ferdinand
          thank you very much solved my doubts
          JH23
            Hello @JH23,
            without further questions or postings, we will consider this topic as solved by Wednesday and flag it accordingly.
