    Insert User Data Track in Python
    10 Posts 3 Posters 1.8k Views 1 Watching
      Hugo BATTISTELLA
      I would like to add track (timeline) for each user data I have set on a object .
      Here is the code I tried, but I don't know why it's not working
      Here is the code I wrote :
      from c4d import gui
      #Création d'une piste pour chaque donnée utilisateur
      def AddAnimationTrack(op):
          LED = c4d.CTrack(op,c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA,1,c4d.DTYPE_GROUP),c4d.DescLevel(c4d.ID_USERDATA,2,c4d.DTYPE_GROUP),c4d.DescLevel(c4d.ID_USERDATA,3,c4d.DTYPE_REAL)))
          op.InsertTrackSorted(LED)
      # Main function
      # Execute main()
      I work on R21.
      You can see the scene here : ADD_TRACK - 1.c4d
      Thank you for helping
      • CairynC Offline
        Cairyn
        Your DescID looks weird. Try something like:
        c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA, c4d.DTYPE_SUBCONTAINER),
                            c4d.DescLevel(userdata_entry,c4d.DTYPE_LONG))
        with userdata_entry being the actual ID of the user data.
        (Disclaimer: I didn't sit down and try this, but the code is from a script dealing with animations (FindTrack), so I'm confident it should work.)
        H 1 Reply Last reply Reply Quote 0
          Hugo BATTISTELLA @Cairyn
          @cairyn said in Insert User Data Track in Python:
          Hello ! Thank you for replying !
          I've put your code but get a error :
          "Traceback (most recent call last):
          File "scriptmanager", line 19, in <module>
          File "scriptmanager", line 15, in main
          File "scriptmanager", line 9, in AddAnimationTrack
          NameError: global name 'userdata_entry' is not defined"
          Maybe I didn't get what I should do with "userdata_entry"
            Hugo BATTISTELLA
            This is what the code looks like now :
            from c4d import gui
                LED = c4d.CTrack(c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA, c4d.DTYPE_SUBCONTAINER),
                                c4d.DescLevel(c4d.ID_USERDATA,3,c4d.DTYPE_LONG)))
            # Main function
            # Execute main()
            • CairynC Offline
              Cairyn @Hugo BATTISTELLA
              @hugo-battistella userdata_entry is a variable I was using in the script. It stands for the ID of the user data entry as shown in the user data dialog on the right side, for example 1 here:
              If you have that user data in your object, you can query op (the selected object) in the console like this:
              op[c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA, c4d.DTYPE_SUBCONTAINER),c4d.DescLevel(1,c4d.DTYPE_REAL))]
              This is also true if the data entry is part of a group.
              • CairynC Offline
                @hugo-battistella The DescID represents a hierarchical structure, so it makes no sense to put ID_USERDATA into the second DescLevel. The first DescLevel identifies the UserData structure within the object. The second DescLevel identifies the entry in that UserData by its ID (for which you'd have to define a proper constant yourself).
                Also, the constructor for a track requires the object as first parameter. This code works for me:
                from c4d import gui
                                c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA,c4d.DTYPE_SUBCONTAINER),
                                c4d.DescLevel(1,c4d.DTYPE_REAL)))
                (provided I have a user data with ID 1 as shown in the screenshot from my last post, and this object is selected.)
                  Hugo BATTISTELLA
                  Hello @Cairyn,
                  thank you a lot for this answer. I try this quikly but now I have a better understanding of the Desclevels concept !
                    Hugo BATTISTELLA
                    That works find ! Thank you so much
                      ferdinand @Hugo BATTISTELLA
                      Hello @Hugo-BATTISTELLA,
                      thank you for reaching out to us. And thank you at @Cairyn for answering the question. We do not have to add anything here, because @Cairyn did already a fantastic job.
                      If you have however follow-up questions, please do not hesitate to ask them.
                        Hello @JH23,
                        without any further questions or postings, we will consider this topic as solved by Wednesday and flag it accordingly.
