    create a material with a set texture?
    r20python
    3 Posts 2 Posters 1.2k Views 1 Watching
    • JH23J Offline
      JH23
      I had a doubt, I wanted to place an established texture on the material created, but I don't know how, since the textures part is not a simple link type data in itself, but if I link directly where the link of the image is born is a bitmap but I don't know how it relates to the material.
          mat = c4d.BaseList2D(c4d.Mmaterial)
          doc.StartUndo()
          doc.AddUndo(c4d.UNDOTYPE_NEW, mat)
          doc.InsertMaterial(mat)
          mat[c4d.MATERIAL_USE_REFLECTION] = False
          #mat[c4d.MATERIAL_COLOR_SHADER] ?
          #Bitmap[c4d.BITMAPSHADER_INTERPOLATION]?
          #Bitmap[c4d.BITMAPSHADER_FILENAME]?
          doc.EndUndo()
      # Execute main()
        The code below will show you how to do that. You must instantiate and insert a Xbitmap shader in your material. In that shader, you can define the texture path.
            texturePath = "C:\\texture.jpg"
            # Creates the new material
            # Start the undo stack
            doc.StartUndo()
            # Insezrt the material into the document
            # Create a new bitmap Shader.
            bitmapShader = c4d.BaseShader(c4d.Xbitmap)
            # Define the filename for the bitmap shader
            bitmapShader[c4d.BITMAPSHADER_FILENAME] = texturePath
            # Set the material color paratemer.
            mat[c4d.MATERIAL_COLOR_SHADER] = bitmapShader
            # Insert the shader in the material's shader list
            mat.InsertShader(bitmapShader)
            # End the undo stack
            doc.EndUndo()
            # Pushes an update event to Cinema 4D
        # Execute main()
        • JH23J Offline
          JH23
          Hi.
          Oh I understand, thanks for your answer, it has helped me a lot.
