    ReadFileToMemory() in R20 crashes
    c++macosr20maxon api
    7 Posts 2 Posters 878 Views 2 Watching
    • fwilleke80F Offline
      fwilleke80
      I know, R20 is a while old, but maybe someone has an idea...
      The following code crashes reproducibly on R20 (definitely on macOS, not yet sure about Windows):
      maxon::Url theServer("https://www.myserver.org/somefolder/somefile.json"_s);
      maxon::BaseArray<Char> memReq;
      iferr (maxon::FileUtilities::ReadFileToMemory(theServer, memReq))
      	DiagnosticOutput("@", err);
      The same (well, almost the same) code works flawlessly in R21 - R23:
      // Set post properties (apparently not yet possible in R20)
      theServer.Set(maxon::URLFLAGS::HTTP_POSTMETHOD, method) iferr_return;
      theServer.Set(maxon::URLFLAGS::HTTP_POSTDATA, maxon::CString(postData, maxon::StringEncodings::Utf8())) iferr_return;
      maxon::BaseArray<maxon::Char> memReq;
      Thanks in advance for advice!
      Frank
      www.frankwilleke.de
        I did tried with R20 and it worked as expected. I'm reading a .txt file from a https link. (i did only tried on windows)
        Could you send us an email with the link you are using ? (just to be sure I'm testing the same thing)
          fwilleke80
          Hi Manuel,
          thanks for your reply!
          Sure, what was the eMail again?
          Frank
          www.frankwilleke.de
            sorry,
            sdk_support(at)maxon(dot)net
              fwilleke80
              Hi Manuel,
              oh, of course. Thanks for the offer!
              Will send you a mail this week. Bit busy these days.
              Frank
              www.frankwilleke.de
                Any news on that one ?
                  fwilleke80
                  Hi Manuel,
                  sorry, I totally forgot about this one. Priorities have changed, so this isn't an issue anymore at the moment.
                  Thanks!
                  Frank
                  www.frankwilleke.de
