    A bug that should be fixed in your Python API code generation (Applies to all recent versions)
    3 Posts 2 Posters 1.1k Views 2 Watching
      mikegold10
      The argument self should not appear in any of the following static method declarations that are part of the generated Python C4D API skeletal/placeholder code, since any good Python IDE will complain and/or flag correct user code that use these methods.
      In the future, you guys can do something like the following in ...resource\modules\python\libs:
      # You can also add the -n flag to the first grep in the pipe chain below, to add line number info after the file name
      grep -R -A2 -H "@staticmethod" * 2>&1 | grep -v "MAXON_" | grep -PB2 "def.*?self"
      I am not sure if the above grep comprehensively captures every one of these issues, but 99-100% of them should have been caught:
      python39/c4d/bitmaps/__init__.py:    @staticmethod
      python39/c4d/bitmaps/__init__.py-    def AllocWrapper(self, bmp):
      python39/c4d/modules/mograph/__init__.py:    @staticmethod
      python39/c4d/modules/mograph/__init__.py-    def Create(self, flags, thread, doc, currentThreadIndex, threadCount, inputs, callers):
      python39/c4d/utils/__init__.py:    @staticmethod
      python39/c4d/utils/__init__.py-    def PickObject(self, bd, doc, x, y, rad, flags):
      python39/c4d/__init__.py:    @staticmethod
      python39/c4d/__init__.py-    def GetDistance(self, v1, v2):
      python39/maxon/decorators.py:            @staticmethod
      python39/maxon/decorators.py-            @wraps(fn)
      python39/maxon/decorators.py-            def Auto(self, *args):
      python39/maxon/decorators.py-            def ReferenceConvert(self, *args):
      python39/maxon/decorators.py-            def Wrap(self, *args):
      python39/maxon/decorators.py-            def NativeDataOrBuiltin(self, *args):
      python39/maxon/decorators.py-            def _MaxonConvertOrFail(self, *args):
      python39/maxon/interface.py:    @staticmethod
      python39/maxon/interface.py-    def Free(self):
      python39/maxon/interface.py-    def GetLocal(self):
      python39/maxon/interface.py-    def AllocEmpty(self):
      python39/maxon/interface.py-    def AllocFromUuid(self, uuid):
      python39/maxon/interface.py-    def AllocFromString(self, uuidStr):
      python39/maxon/interface.py-    def DescribeIO(self):
      python39/maxon/interface.py-    def CreateUuidString(self):
      python39.win64.framework/lib/pathlib.py:        @staticmethod
      python39.win64.framework/lib/pathlib.py-        def link_to(self, target):
      Also, for all of the following, the @classmethod attribute should be changed to @staticmethod and the self argument should be removed, just like for the above cases:
      python39.win64.framework/lib/importlib/_bootstrap.py-    @classmethod
      python39.win64.framework/lib/importlib/_bootstrap.py:    def create_module(self, spec):
      python39.win64.framework/lib/importlib/_bootstrap.py:    def exec_module(self, module):
      python39.win64.framework/lib/_collections_abc.py-    @classmethod
      python39.win64.framework/lib/_collections_abc.py:    def _from_iterable(self, it):
        Thanks a lot some are false positive or even coming from the standard library.
        But I will fix the one that are wrong and update the doc 🙂
          mikegold10
          Hi, Maxime, great!
          if I come across any additional issues of a similar nature, I'll update this post.
