    Write a python code into a Python Effector
    10 Posts 3 Posters 2.3k Views 1 Watching
      Hugo BATTISTELLA
      I want to insert a code (not written yet) into a python effector I created through a Python script. I figured out how to open the Editor but not how to change the code inside.
      Can you help please ?
      (running on R21)
      from c4d import gui
      from c4d.modules import mograph as mo
      def PythonEffector():
          PythonEffector = c4d.BaseList2D(1025800)
          #PythonEffector(c4d.OEPYTHON_OPENEDITOR) >> CHANGE THAT CODE WITH SOMETHING ELSE
          doc.InsertObject(PythonEffector)
      # Main function
          PythonEffector()
      # Execute main()
        Hugo BATTISTELLA
        In fact in this Effector I would like to create an id selection for the operator it will be linked to.
        So I can add this code into the effector
        • CairynC Offline
          Cairyn
          Simply address the code field as a string:
          PythonEffector[c4d.OEPYTHON_STRING] = "# This is some Python code I'd like to see"
          • CairynC Offline
            Cairyn @Hugo BATTISTELLA
            @Hugo-BATTISTELLA said in Write a python code into a Python Effector:
            Not sure whether I understand what you want... but changing the cloner the effector is used in from within the effector seems very unadviseable to me, as an Effector can be used in more than one cloner.
            If you have a specific Cloner in mind, you can access its list of effectors through
            Cloner[c4d.ID_MG_MOTIONGENERATOR_EFFECTORLIST]
            But I guess you mean something else by "operator"...?
              Hugo BATTISTELLA
              TEST_CLONERS_2.c4d
              @Cairyn thank you for answer
              I can now add a line of code but how Can I add multiples lignes of code in the effector. I got some difficulties to manage this.
              What I would like is to make a selection by ID of the cloner through the Python Effector.
              • CairynC Offline
                TEST_CLONERS_2.c4d
                Basic Python multiline strings?
                PythonEffector[c4d.OEPYTHON_STRING] = (
                    "# This is some Python code I'd like to see\n"
                    "# A second line\n"
                    "import c4d\n"
                    "main()"
                As far as I can see, there is no way to retrieve the cloner the effector is currently working on from the MoData that you can call up. Have you studied all the examples already? (Linked in the MoData docs)
                See also push_apart_effector.c4d, py_effector_random.c4d and py_effector_shape.c4d scene examples.
                  Hugo BATTISTELLA
                  The multilines code works well.
                  Do you mean that there is no possibility to select clones ID to affect them with the Python Effector ?
                  • CairynC Offline
                    uh, you said "ID of the cloner" originally. Not clones.
                    If you want to identify a single clone, you can use the MoData function
                    index = md.GetCurrentIndex()
                    But that's part of the default code in the Python effector already.
                    (And the reference for the current cloner can be read from the predefined variable gen.)
                      Hi @Hugo-BATTISTELLA and @Cairyn,
                      thank you for reaching out to us. And thank you @Cairyn for stepping in. We cannot add anything to what @Cairyn already said. We would like however to bring up the fact that topics should be single subject as defined in the Forum Guidelines, as otherwise content will be hard to find for other users. It is fine in this case, but in the future, please open multiple topics for questions that are not direct follow-up questions, but questions with a new scope.
                        Hugo BATTISTELLA
                        @Cairyn Thank you for your help ! That's it. I confused it all with the wrong word. Sory... Your answers help me very nicely
                        @ferdinand I apologize about going out of the guidelines. I understand this and will create new topic for that point
