    startup script in R23 not working anymore
    r23python
    3 Posts 2 Posters 610 Views 1 Watching
      marc_angele
      hello guys,
      i finally updated to R23 and have now an issue with my startup code.
      to load and set some variables i used the $g_prefspath/python37/maxon_generated/__init__.py file.
      in R21 it worked perfectly. now in R23 the script didn't execute anymore.
      i tried to delete the library and tested it on different machines.
      does some of you have an idea?
      or is there a better solution to execute some python code at startup?
      thank you for any help!
      best,
      marc.
        Hi @marc_angele,
        thank you for reaching out to us. Your problem is caused due to a change of how Python is integrated with R23+ compared to R20.
        • First of all, you are not really supposed to modify {USERPREFS}/python37/maxon_generated/__init__.py, as this is a file for internal usage. So this was never a feature in the first place 😉
        • You can however still modify it, and it will still work as long as you have a plugin installed which imports the maxon package. Your code will be then executed when this plugin imports the package.
        • Better solutions would be however:
          a. Create a file called python_init.py as{USERPREFS}/python37/python_init.py. It will mostly work like an __init__.py, here you can find its (slightly outdated) documentation.
          b. Implement some kind of plugin and implement PluginMessage() and hook into C4DPL_INIT_SYS or C4DPL_INIT which are very early points to execute code in the boot up of Cinema 4D. Both for python_init.py and PluginMessage() applies that due to this early stage of the boot-up of Cinema, you won't have full functionality of all modules yet.
        For more complex tasks you might have to run a script with c4dpy before you actually start Cinema or postpone your code to a later point in PluginMessage.
          marc_angele
          hi @ferdinand
          thank you very much for your response!
          the python_init.py does the job perfectly 🙂
          great support, thanks a lot!
          best,
          marc.
