    How to download a file in R20+
    maxon apir21s22r23
    5 Posts 2 Posters 633 Views 2 Watching
    • fwilleke80F Offline
      fwilleke80
      How would I go about downloading a (text) file from a webserver? Ideally, this should be done in a separate thread, so the GUI isn’t blocked while waiting for the server response?
      I just want to read what’s in the file, it doesn’t need to be stored locally.
      I know, using a separate Python plugin it is very easy, but I’d prefer doing it in C++. If it's possible in R20 - R23, even better.
      Thanks in advance & greetings,
      Frank
      www.frankwilleke.de
        you should have a look at this thread from which, we've updated the documentation.
        Using the function ReadFileToMemory you can read the stream to an array and you can use ConvertTextToLines. to have a per-line result
        ReadFileToMemory is present since R20 but i didn't tried there.
        Let me know if it's working, otherwise I will have a look if i find something better.
          fwilleke80
          Hi Manuel,
          thanks, that looks exactly like the thing I need!
          Was only looking into NetworkHttpHandlerInterface the whole time...
          I'll try this out soon and then report back.
          Will set this thread to solved, as my question was answered 🙂
          Thanks & greetings,
          Frank
          www.frankwilleke.de
            fwilleke80
            It's working perfectly, thanks again!
            So much easier than I thought 🙂
            Frank
            www.frankwilleke.de
              by the way, i forgot to talk about the thread thing.
              This thread might help
              And of course our manuals about threading
