    SaveDocument Unexpected Behavior in R23
    3 Posts 2 Posters 642 Views 1 Watching
    • K Offline
      Kon Q
      Hello there,
      I tried to export the OBJ file using c4d.documents.SaveDocument(). The return value always be true, but I cannot find the exported file.
      I can reproduce this issue using the script from the official repository:
      https://github.com/PluginCafe/cinema4d_py_sdk_extended/blob/master/scripts/03_application_development/files_media/export_obj_r13.py
      This issue only appears in Cinema 4D R23, and I also found that the API works after I export an OBJ file using GUI. If I reset the user data by deleting the preferences folder, it doesn't work again.
      Cinema 4D version: R23.110
      System: macOS 11.2.3
      Kon
        you have to add this line if you don't want animated object.
        At least for now, I'm going to check with the devs if it's our code (conditions) or the "default" parameters that are missing
            objExport[c4d.OBJEXPORTOPTIONS_ANIMATION_TYPE] = c4d.OBJEXPORTOPTIONS_NO_ANIMATION
        or one of those if you want animation :
        can be on of those if animation is wanted.
        OBJEXPORTOPTIONS_MANUAL_RANGE
        OBJEXPORTOPTIONS_LOOP_FRAMES
        OBJEXPORTOPTIONS_PREVIEW_FRAMES
        OBJEXPORTOPTIONS_ALL_ANIMATED_FRAMES
        objExport[c4d.OBJEXPORTOPTIONS_ANIMATION_TYPE] == c4d.OBJEXPORTOPTIONS_ALL_ANIMATED_FRAMES
        K 1 Reply Last reply Reply Quote 0
        • K Offline
          Kon Q @Manuel
          @m_magalhaes
          Thank you so much for the help! The script works fine after adding this line.
          Kon
