    Undo Problem For TagData Plugin
    pythonr23
    4 Posts 2 Posters 919 Views 2 Watching
    • beatgramB Offline
      beatgram
      Hey folks,
      I encountered Undo related issue again. It might be due to my lack of understanding for undo things but let me ask you a question.
      I wrote a test tag plugin with python which follows another object's position with a little offset.
      It simply works but when I undo, the object that has the tag doesn't react until I click somewhere (see below).
      Is it possible to solve this issue with python?
      I know undo things are prohibited in execute() of tagdata, so is there any workaround?
      Please help me if you know the solution.
      Here's quick code for this.
      testtag.pyp
      import os
      from c4d import plugins, bitmaps, utils
      PLUGIN_ID = *******
      class TestTagData(plugins.TagData):
          def Init(self, node):
              pd = c4d.PriorityData()
              if pd is None:
                  raise MemoryError("Failed to create a priority data.")
              pd.SetPriorityValue(lValueID = c4d.PRIORITYVALUE_MODE, data = c4d.CYCLE_INITIAL)
              node[c4d.EXPRESSION_PRIORITY] = pd
          def Execute(self, tag, doc, op, bt, priority, flags):
              bc = tag.GetDataInstance()
              obj = bc.GetLink(c4d.TTEST_TARGET_OBJECT)
              if obj is None:
                  return False
              mrx = obj.GetMg()
              mrx.off += c4d.Vector(100, 0, 0)
              op.SetMg(mrx)
              return c4d.EXECUTIONRESULT_OK
          plugins.RegisterTagPlugin(id = PLUGIN_ID, str = "Test Tag", info = c4d.TAG_EXPRESSION | c4d.TAG_VISIBLE, g = TestTagData, description = "ttest", icon = None)
      ttest.res
      CONTAINER Ttest
          NAME Ttest;
          INCLUDE Texpression;
          GROUP ID_TAGPROPERTIES
              LINK TTEST_TARGET_OBJECT
                  ANIM ON;
                  ACCEPT { Obase; };
        this is probably a bug here, i need to investigate a bit more.
        Instead of retrieving the object using the BaseContainer, use the bracket notation.
        You will receive the right object with the correct Matrix.
        obj = tag[c4d.TTEST_TARGET_OBJECT]
        beatgramB 1 Reply Last reply Reply Quote 0
        • beatgramB Offline
          beatgram @Manuel
          @m_magalhaes Thank you for your checking, Manuel.
          I didn't think it's a bug! And yep, your workaround with bracket notation works fine.
          So these bracket notation style is safer than using BaseContainer in any case?
          Anyway, let us know if you confirm this is a bug.
            Manuel @beatgram
            @beatgram said in Undo Problem For TagData Plugin:
            this should be exactly the same.
            Sorry i didn't got time to warp my head around it.
