    skin weights import
    Scheduled Pinned Locked Moved General Discussion
    3 Posts 0 Posters 864 Views
      On 23/09/2003 at 05:20, xxxxxxxx wrote:
      I've played a little with the LWS/LWO import in C4D. It works fine (with only 1 layer) except for the weights of the vertices. When I check with the well named "Claude Bonet" tool, the mesh is left blank in the viewport, so the default bone influence (1/r^2) is used ...
      So here is my question : is it a bug of the LWO importer or something impossible to do with the SDK ?
      Thanks in advance,
      -sebastien
        On 21/11/2003 at 07:56, xxxxxxxx wrote:
        Post this as suggestion to MAXON.
        Of course you can always write your own LWO importer supporting that feature!
          On 21/11/2003 at 08:19, xxxxxxxx wrote:
          It was simpler to write an importer for our custom format (supporting multilayer and weights & bones) 🙂
