    Creating a Keyframe similar to Ctrl-Clicking the Curve
    r23windowspython
    3 Posts 2 Posters 515 Views 2 Watching
    • ? Offline
      A Former User
      When in the Timeline, if I hold Ctrl/Cmd and click on the curve, Cinema 4D adds a keyframe that matches the contour of the curve perfectly.
      The tangents of the new key and neighboring keys are properly weighted.
      When I try to do this with the code below, I get a keyframe whose angles do not match the curve and where the Left & Right times of the neighboring keys are not adjusted.
      keyDict = keyCurve.AddKey(keyTime)
      keyIndex = keyDict["nidx"]
      key = keyDict["key"]
      key.SetValue(keyCurve,value)
      key[c4d.ID_CKEY_PRESET] = c4d.ID_CKEY_PRESET_NEWAUTOWEIGHTED
      Result:
      The tangents of the key seem to be weighted properly using ID_CKEY_PRESET_NEWAUTOWEIGHTED, but how can I get the angle of the tangents to match the curve and the Left & Right Time of the neighboring keys to adjust so the curve's contour doesn't change as in the Ctrl-Click key creation scenario?
      Thank you!
        Hi @blastframe,
        thank you for reaching out to us. One built in solution you could use is CCurve.AddKeyAdaptTangent() instead of CCurve.AddKey(). It will allow you to insert a smoothly interpolated key between two other keys and the result will look something like the attached image. I also attached a modified github ctrack_create_keys_r13.py example at the end. You only have to read the snip parts, everything else is unchanged.
        I hope this helps, if not, I would have to ask you to restate your goals.
        Copyright: MAXON Computer GmbH
        Author: Manuel MAGALHAES
        Description:
            - Creates position Y tracks.
            - Adds two keyframes.
            - Sets their value and interpolation.
        Class/method highlighted:
            - CKey.SetInterpolation()
            - CKey.SetKeyDefault()
        Compatible:
            - Win / Mac
            - R13, R14 R15, R16, R17, R18, R19, R20, R21, S22, R23
        def CreateKey(curve, time, value, interpolation):
            Creates a Key on the given curve at the given time with a given value and with the given interpolation.
            :param curve: The Curve where to add the keyframe.
            :type curve: c4d.CCurve
            :param time: The time of the keyframe.
            :type time: c4d.BaseTime
            :param value: The value of the keyframe.
            :type value: float
            :param interpolation: The interpolation of the key along the curve.
            :type interpolation: c4d.CINTERPOLATION_XXX
            :return: They key and the index of the key in the CCurve.
            :rtype: tuple(c4d.Ckey, int)
            :raise MemoryError: If for some reason, it was not possible to create the key.
            # Adds the key
            keyDict = curve.AddKey(time)
            # Checks if the key have been added
            if keyDict is None:
                raise MemoryError("Failed to create a key")
            # Retrieves the inserted key
            # Sets the value of the key
            key.SetValue(curve, value)
            # Mandatory: Fill the key with default settings
            curve.SetKeyDefault(doc, keyIndex)
            # Changes it's interpolation
            key.SetInterpolation(curve, interpolation)
            return key, keyIndex
            # Creates the object in memory
            obj = c4d.BaseObject(c4d.Ocube)
            # Creates the track in memory. Defined by it's DescID
            trackY = c4d.CTrack(obj, c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_POSITION, c4d.DTYPE_VECTOR, 0),
                                                c4d.DescLevel(c4d.VECTOR_Y, c4d.DTYPE_REAL, 0)))
            # Gets curves for the track
            curveY = trackY.GetCurve()
            # Creates a key in the Y curve with value 0 at 0 frame with a spline interpolation
            keyA, keyAIndex = CreateKey(curveY, c4d.BaseTime(0), value=0, interpolation=c4d.CINTERPOLATION_SPLINE)
            # Retrieves time at frame 10
            keyBTime = c4d.BaseTime(10, doc.GetFps())
            # Creates another key in the Y curve with value 100 at 10 frame with a spline interpolation
            keyB, keyBIndex = CreateKey(curveY, keyBTime, value=100, interpolation=c4d.CINTERPOLATION_SPLINE)
            # --- snip ---
            # Add key in between the keys A and B.
            bt = c4d.BaseTime(5, doc.GetFps())
            curveY.AddKeyAdaptTangent(bt, True, True)
            # --- snip ---
            # Inserts the track containing the Y curve to the object
            obj.InsertTrackSorted(trackY)
            # Inserts the object in document
            doc.InsertObject(obj)
            # Pushes an update event to Cinema 4D
        # Execute main()
        ? 1 Reply Last reply Reply Quote 1
        • ? Offline
          A Former User @ferdinand
          @ferdinand That was exactly what I was seeking, thank you, Ferdinand! 😄
