    ReferenceError when trying to Cache a GeClipMap
    pythonwindowsr23
    3 Posts 2 Posters 369 Views 2 Watching
    • ? Offline
      A Former User
      I'm trying to create a crude example of caching the Bitmaps/GeClipMaps and I'm running into an error I can't seem to solve. In the code below, self.UpdateBackgroundCache() works, but self.UpdateBoxCache() does not. In this function, I'm creating a GeClipMap, initializing it, drawing a rectangle, and storing the clipmap's BaseBitmap as a property of the GeUserArea. I keep getting the error:
      ReferenceError: the object 'c4d.bitmaps.BaseBitmap' is not alive
      Can anyone help me understand what is going wrong? Thank you!
      from c4d import gui,bitmaps
      GADGET_ID_GEUSERAREA = 10000
      def drawColorBitmap(w,h,r,g,b):
          r = int(r * 255)
          g = int(g * 255)
          b = int(b * 255)
          bmp = bitmaps.BaseBitmap()
          bmp.Init(w, h, 24)
          for wPixel in range(w):
              for hPixel in range(h):
                  bmp.SetPixel(wPixel, hPixel, r, g, b)
          return bmp
      class MyUserArea(c4d.gui.GeUserArea):
          def __init__(self):
              self.boxX = 50
              self.boxY = 50
              self.boxWidth = 50
              self.boxHeight = 50
              self.boxAngle = 0
              self.boxOpacity = 1.0
              self.bgCache = None
              self.boxCache = None
          def UpdateBackgroundCache(self,x2,y2):
              self.bgCache = drawColorBitmap(x2,y2,0.35,0.35,0.35)
          def UpdateBoxCache(self):
              rMap = c4d.bitmaps.GeClipMap()
              rMap.Init(self.boxWidth, self.boxHeight)
              rMap.BeginDraw()
              rMap.SetDrawMode(c4d.GE_CM_DRAWMODE_BLEND,
                  c4d.GE_CM_SRC_MAX_OPACITY)
              rMap.SetColor(255,0,0,255)
              rMap.FillRect(0,0,50,self.boxHeight)
              rMap.EndDraw()
              self.boxCache = rMap.GetBitmap()
          def GetMinSize(self):
              return 300,150
          def UpdateCache(self):
              #Cache Background
              if self.bgCache == None:
                  self.UpdateBackgroundCache(self.GetWidth(),self.GetHeight())
              #Cache Red Box
              if self.boxCache == None:
              #Blit Red Box with Background
              clipMap = bitmaps.GeClipMap()
              clipMap.InitWithBitmap(self.bgCache, None)
              clipMap.BeginDraw()
              clipMap.SetDrawMode(c4d.GE_CM_DRAWMODE_BLEND,
              rectMap = bitmaps.GeClipMap()
              rectMap.InitWithBitmap(self.boxCache, None)
              clipMap.Blit(self.boxX, self.boxY,
                  rectMap, 0, 0, self.boxWidth, self.boxHeight,
                  rop = c4d.GE_CM_BLIT_COL)
              clipMap.EndDraw()
              bmp = clipMap.GetBitmap()
              return bmp
          def DrawMsg(self, x1, y1, x2, y2, msg):
              cache = self.UpdateCache()
              self.DrawBitmap(cache, x1, y1, x2, y2, 0, 0, 300, 150, c4d.BMP_NORMAL | c4d.BMP_ALLOWALPHA)
      class ExampleDialog(c4d.gui.GeDialog):
          geUserArea = MyUserArea()
          def CreateLayout(self):
              self.SetTitle("ClipMap")
              self.AddUserArea(GADGET_ID_GEUSERAREA, c4d.BFH_CENTER | c4d.BFH_SCALE | c4d.BFV_CENTER | c4d.BFV_SCALE, 300, 150)
              self.AttachUserArea(self.geUserArea, GADGET_ID_GEUSERAREA)
          global dlg
          dlg = ExampleDialog()
          dlg.Open(c4d.DLG_TYPE_ASYNC, defaultw=400, defaulth=250, xpos=-2, ypos=-2)
        Hi @blastframe,
        thank you for reaching out to us. The error ReferenceError: the object 'xyz' is not alive means that something has deallocated the object you are trying to reference. This happens because you have two competing memory management systems, one provided by Python, its gc, and one provided by Cinema's C++ API. In this case the method GeClipMap.GetBitmap() (Link to C++ Doc) only does return a pointer, i.e. an object that is owned by the GeClipMap. To avoid the error, you have either to avoid the GeClipMap being garbage collected or clone the bitmap so that you have full ownership. I "fixed" your code by just plastering in two .GetClone().
        FOO = None
            r = int(r * 255)
            g = int(g * 255)
            b = int(b * 255)
            bmp.Init(w, h, 24)
            return bmp
            def __init__(self):
                self.boxX = 50
                self.boxY = 50
                self.boxWidth = 50
                self.boxHeight = 50
                self.boxAngle = 0
                self.bgCache = None
                rMap.BeginDraw()
                rMap.EndDraw()
                # The bitmap returned by GeClipMap.GetBitmap() is owned by the
                # GeClipMap. Leaving the scope of this function will free the
                # GeClipMap and with it the attached BaseBitmap.
                bitmap = rMap.GetBitmap()
                # Either clone the bitmap or also reference the GeClipMap so that
                # it won't be deallocated on exit.
                self.boxCache = bitmap.GetClone()
                return 300,150
                #Cache Background
                #Cache Red Box
                clipMap.BeginDraw()
                clipMap.EndDraw()
                # The same thing applies here.
                return bmp.GetClone()
            global dlg
        • ? Offline
          A Former User @ferdinand
          @zipit Thank you very much, Ferdinand. This helped me a lot!
