    Content Browser and StrNotFound
    r23python
    4 Posts 2 Posters 575 Views 1 Watching
    • P Offline
      pim
      I installed (R23) our plugin (MeshBoolean), but now the File entry of the Content Browser gives a "StrNotFound".
      In R20 it was ok.
      The console shows no warnings or errors.
      Choosing another layout or another Node Space does not help.
      But you can still select the 'File' option.
        Hard to say without more informations.
        this menu entry is using the Symbol BROWSER_FILE_MENU define inside the file : resource\modules\browser\c4d_symbols.h and the str file in resource\modules\browser\strings_en-US\c4d_strings.str
        the id should be 10002.
        Did you tried to run c4d with the console open to see if there's any error message ?
        • P Offline
          pim
          Ok, I found out that the issue is in "c4d_symbols.h"
          There I defined FILE = 1010011.
          After removing the FILE definition, it was ok again.
          Setting FILE = 10002 did not solve the issue.
          So removing it and defining FLE somewhere else, will be ok.
          enum
          ResBasedMenu =  101001,
          MY_CHECKBOX  =  101002,
          CURR_SIZE_STR = 101003,
          NEW_X =         101004,
          NEW_Y =         101005,
          NEW_Z =         101006,
          MY_TEXTBOX =    101007,
          BUTTON_CANCEL = 101008,
          BUTTON_OK =     101009,
          BUTTON_RESET =  1010010,
          // FILE =          1010011,
          // FILE =          10002,
          MYBITMAPBUTTON =1010012,
          IDC_CUSTOM1 = 1010013,
            i was saying not to use the same ID (in case of conflict)
            But it seems that there's no conflict neither with the symbol name or the symbol ID.
            A bit strange.
