    Default Object: How to apply those defaults?
    c++r20r21s22r23
    11 Posts 2 Posters 1.5k Views 1 Watching
    • fwilleke80F Offline
      fwilleke80
      The Attribute Manager, the Edit menu offers the option "Set as Default...". This will save the active object as default for this object type. So far, so good.
      Creating a Cube, changing some attributes, and then setting it as default works fine. When I create a new Cube, it has my attribute settings.
      However, it does not work in two cases:
      1. With Field Objects that are added via a FieldList description in one of my plugin objects (or an object, for that matter)
        I can change settings in that Field Object, and set it as default. But when I create a new Field from the FieldList description in my plugin object, the created Field does not have my settings. The settings are only applied when I create a Field of that type from Cinema's Create menu.
      2. With objects that are added to the document via plugin code
        I do the normal stuff when adding an object to the scene via e.g. a command:
      		BaseObject *newObjectPtr = BaseObject::Alloc(id);
      		if (! newObjectPtr)
      			return false;
      		doc->StartUndo();
      		doc->InsertObject(newObjectPtr, op->GetUp(), op, true);
      		doc->SetActiveObject(newObjectPtr);
      		newObjectPtr->Message(MSG_UPDATE);
      		doc->AddUndo(UNDOTYPE::NEWOBJ, newObjectPtr);
      		doc->EndUndo();
      		EventAdd();
      But it's the same as with the Field objects, after setting an object as default, and creating another one (using the above code), the settings are not applied. It only works when creating the new object via Cinema's Create menu or from the plugin's menu.
      So here are the questions:
      1. How can I add the default object, that the user has set, to the document?
      2. Where are those default objects stored, by the way, and how can we remove a default object?
        Already solved: In the Content Browser under Presets/Defaults.
      Thanks in advance, greetings,
      Frank
      www.frankwilleke.de
        fwilleke80
        Follow-up: The behavior is the same when using the FieldList of any Effector. Adding a Field from the FieldList does not add the default object that the user has set.
        So I guess it's nothing we can change. Or is there a way to load those default settings from somewhere and apply them? There must be, as the code that adds objects from the Create or the plugin's menu obviously does it 😉
        www.frankwilleke.de
          sorry for the delay, the default properties are stored in the Browser. you can retrieve them with GetDefaultObject. You will find more information on that page
          BaseObject* myDefaultObject = static_cast<BaseObject*>(SDKBrowser::GetDefaultObject(Opyramid));
          	if (myDefaultObject == nullptr)
          		myDefaultObject = BaseObject::Alloc(Opyramid);
          		return maxon::NullptrError(MAXON_SOURCE_LOCATION);
            fwilleke80
            oops, sorry, didn't see your reply earlier (I never get notification emails).
            Thank you very much, that should be the solution at least for the objects I create in my code 🙂
            However, I guess, there is no way to use the default object for Fields created by the FieldList customgui, right?
            Frank
            www.frankwilleke.de
              @fwilleke80 said in Default Object: How to apply those defaults?:
              I don't think so. But what's strange is that it does create your default field if you use the palette (icon on top).
              We could maybe consider that as a bug.
              I need to check the code to see why there's such a difference between the palette and the customGUI.
              fwilleke80F 1 Reply Last reply Reply Quote 0
                fwilleke80
                Good to know, thank you for looking into it!
                Frank
                www.frankwilleke.de
                  fwilleke80 @Manuel
                  @m_magalhaes said in Default Object: How to apply those defaults?:
                  I guess, that's because menus and palettes create the objects using menu item resource IDs like PLUGIN_CMD_440000266 (e.g. in /resource/c4dplugin/menus/c4d_m_editor.res), which I guess was a quick solution back when it was coded. It's a kind of CommandData that creates the objects, apparently invoking SDKBrowser::GetDefaultObject(). This has probably just been forgotten in the FieldListCustomGui.
                  I wonder if there's a way to call that 'secret' CommandData from a plugin.
                  Frank
                  www.frankwilleke.de
                    those commands are created whenever you register a plugin/tools etc.
                    after having a look at it, i confirm it's a bug, the object is allocated without checking for the content browser.
                    if it's in your objectData, you could maybe listen to the message MSG_DOCUMENTINFO_TYPE_OBJECT_INSERT, check if it's a field object and check if it's the default one or the browser one. Than replace according to what you want.
                    I didn't tested it myself but it could work.
                    But that's maybe too mush work for a "detail"
                      fwilleke80
                      Oh, that is actually a good idea, thank you!
                      I'll try that!
                      Frank
                      www.frankwilleke.de
                        fwilleke80
                        Sadly, it seems that MSG_DOCUMENTINFO is not sent when adding a Field via the FieldList CustomGui. I had been hoping that message would be triggered by BaseDocument::InsertObject() and GeListNode::InsertUnder() (and related functions).
                        I guess, we have to do without default objects in this case 😕
                        Frank
                        www.frankwilleke.de
                          well sorry for the misleading.
                          I was thinking it should work because the object is inserted with doc->InsertObject
