    Rename object by filename
    10 Posts 3 Posters 1.9k Views 1 Watching
    • J Offline
      Jasper Sek
      Hi there! Do someone know a way to rename a nullobject in c4d by the filename, so that the name of the null-object changes, if the c4d-file changes? I mean something like the token-system at the renderpath.
      I never used python before, just a bit of xpresso. That would save me and maybe others a lot of time.
      • lasselauchL Offline
        lasselauch
        You just need to add a python tag to your object and paste the following code.
        Simple as that:
            if not doc:
            doc_name = doc.GetDocumentName()
            null = op.GetMain()
            if not null:
            null.SetName(doc_name)
        Download here: null-docname.c4d
        Hope it helps.
        Lasse
        J 1 Reply Last reply Reply Quote 3
        • J Offline
          Jasper Sek
          Wow, Thanks a lot!
          • J Offline
            Jasper Sek @lasselauch
            @lasselauch What if i just want the name without .c4d?
              lasselauch
              http://letmegooglethat.com/?q=split+extension+from+filename+python
              • J Offline
                @lasselauch sorry i'm too bad at this. cant fix that. i found this before, but i don't know how to implement it in c4d.
                  lasselauch
                  Of course there are a lot of ways to spin this, but I guess in most cases this should be enough:
                  # import os
                      if not doc:
                      docname = doc.GetDocumentName()
                      # docname, _ = os.path.splitext(docname)
                      docname = docname.replace('.c4d', '')
                      null = op.GetMain()
                      if not null:
                      null.SetName(docname)
                  Download: null-docname.c4d
                  Lasse
                    Hi @Jasper-Sek,
                    thank you for reaching out to us. And thank you @lasselauch for jumping in. The solutions provided by @lasselauch are correct, but one might want to consider that Cinema is also capable of opening non-c4d files (I know, it's crazy ;)). So you should use os.path.splitext(docname).
                    PS: @lasselauch I know that you meant this in a light-hearted manner, but "let-me-google-that-for-you" can be misconstrued. People have different information needs and things that seem trivial or obvious to you, are not for them. Programming can be a confusing topic and we would like this to be a welcoming place for everyone and subsequently stay away from all "RTFM"-notions.
                    lasselauchL 1 Reply Last reply Reply Quote 1
                      lasselauch @ferdinand
                      @zipit said in Rename object by filename:
                      Yep, definitely meant in a light-hearted manner!!! πŸ™‚
                      You're totally right.. that's why I provided the correct answer.
                      Lasse
                      • J Offline
                        Jasper Sek
                        @zipit @lasselauch thank you both for your time and knowledge!
