    Cannot set ID_BASEOBJECT_USECOLOR to a child object.
    4 Posts 2 Posters 989 Views 1 Watching
      mastergog
      Hey guys, i'm on R23, Windows, C++ and I have an issue setting ID_BASEOBJECT_USECOLOR.
      Basically I have a spline object as a sub-object of my ObjectData plugin which I want to have a solid color.
      In GetVirtualObjects() before inserting this spline under my cache root, I use the following:
                              splineObject->SetParameter(DescID(ID_BASEOBJECT_USECOLOR), ID_BASEOBJECT_USECOLOR_ALWAYS, DESCFLAGS_SET::NONE);
      			splineObject->SetParameter(DescID(ID_BASEOBJECT_COLOR), Vector(1,0,1), DESCFLAGS_SET::NONE);
      But this doesn't work...
      Also tried setting with the ObjectColorProperties struct but no luck:
                              ObjectColorProperties props;
      			props.color = Vector(1, 0, 1);
      			props.usecolor = ID_BASEOBJECT_USECOLOR_ALWAYS;
      			splineObject->SetColorProperties(&props);
      Any ideas what I'm doing wrong?
      EDIT: In edit mode I manage to do set them separately for each of my objects, so I assume it's possible.
      Thank you for the attention!
      -Georgi.
        mastergog
        One thing that wasn't mentioned.
        All the children objects seem to inherit the properties from the base object. If I set the base objects properties with the code in my previous post, the spline object will receive them.
        Maybe there's a way to tell some objects to inherit and others to not?
          Hi @mastergog please for your next topic, try to use the Q&A functionality.
          Regarding your issue, you should first register your object plugin with the flag OBJECT_USECACHECOLOR.
          Then if you are returning multiple objects a good practice is also to define an UniqueIP for each of them, for more information please read BaseObject - Generating
            mastergog @m_adam
            @m_adam Yay thank you very much! Was almost ready to compromise with the default color.
            Will use the Q&A functionality, excuse me for the posts so far.
            Warm regards,
            Georgi.
