    ZeroAxis R23 help
    pythonr23
    11 Posts 3 Posters 2.4k Views 1 Watching
    • P Offline
      peXel
      Hi There,
      I had for R21 this script. It was working like reset PSR, but for the object axis only.
      Could anyone help me please to get this great little helper back for the R23?
      Thank you very much,
      Best,
      Peter
      from c4d import Vector as V
          if op is None or not op.CheckType(c4d.Opoint):
              return False
          ObjMatrix = op.GetMg()
          ObjPoints = op.GetAllPoints()
          Pcount = op.GetPointCount()
          doc.StartUndo()
          op.SetAbsRot(V(0))
          op.SetAbsPos(V(0))
          op.Message(c4d.MSG_UPDATE)
          NewMatrix = op.GetMg()
          for point in xrange(Pcount):
              op.SetPoint(point,~NewMatrix*ObjMatrix*ObjPoints[point])
          doc.EndUndo()
      • X Offline
        x_nerve
        Hi:
        Your code should run in R23. The following provides additional reset axis code.Unless you're talking about point location resetting, which is non-destructive modeling, and if you want to implement it, you'll need to consider point deletion, etc. It's recommended to use the Python plug-in or the Python tag.
        #from c4d import Vector as V
            #if op is None or not op.CheckType(c4d.Opoint):
                #return False
            ObjMatrix.off = c4d.Vector(0, 0, 0)
            #ObjPoints = op.GetAllPoints()
            #Pcount = op.GetPointCount()
            doc.StartUndo()
            #op.SetAbsRot(V(0))
            #op.SetAbsPos(V(0))
            #NewMatrix = op.GetMg()
            point = [ op.GetAllPoints()[i] * op.GetMg() * ~ObjMatrix
                        for i in range(op.GetPointCount()) ]
            op.SetMg(ObjMatrix)
            op.SetAllPoints(point)
            doc.EndUndo()
        • P Offline
          peXel
          Hi x_nerve,
          thank you very much it does work now like expected!
          Best,
          Peter
            Hi @peXel,
            thank you for reaching out to us and thanks to @x_nerve for jumping in. Can we considered this question to be solved or are there any follow up questions?
            • P Offline
              peXel
              This post is deleted!
              • P Offline
                peXel
                Hi There,
                the script is not working properly sadly. It does set the axis back to 0,0,0, but it stays it's orientation.
                It needs to copy the axis orientation same as the object one up in hierarchy, see original code.
                What did change inside the SDK and how do I get this behavior back again?
                Thank you very much for your help, it's a great helper for everybody if it does work again
                Best,
                Peter
                • X Offline
                  x_nerve
                  Hi:
                  @peXel
                  Sorry, I was negligent. The reset code of rotation and zoom is as follows.
                      if op.CheckType(c4d.Opolygon):
                              #return False
                          ObjMatrix = c4d.Matrix() #op.GetMg()
                          doc.StartUndo()
                          #op.SetAbsRot(V(0))
                          #op.SetAbsPos(V(0))
                          op.SetMg(ObjMatrix)
                          doc.EndUndo()
                          doc.StartUndo()
                          op.SetMg(c4d.Matrix())
                          doc.EndUndo()
                    ferdinand @peXel
                    Hi @peXel,
                    thank you for reaching out to us. Unfortunately it is not quite clear to me what you expect from this script and what you do consider to be not working in your first version. If your request was simply about the NameError your first script is throwing in R23, that is because Cinema switched from Python 2.7 to Python 3.7. Which in turn means that xrange is finally gone now in Cinema's Python. You have to use range now (which does not really change much for you). Below you will find a "fixed" version (I just removed the x from xrange 😄 😞
                            return False
                        doc.StartUndo()
                        op.SetAbsRot(V(0))
                        op.SetAbsPos(V(0))
                        for point in range(Pcount):
                        doc.EndUndo()
                    • P Offline
                      peXel
                      Hi Zipit,
                      yes that's it, now it's working like expected. Should be integrated in our main C4D core, like reset PSR
                      Thanks for solving it!
                      Yes it was just removing the x, because I don't have any clue about Python 2.7 or 3.7 or even changes sadly.
                      It's really a pitty that there's no convert 2.7 to 3.7 script button for nonprogrammers 🙂
                      Best,
                      Peter
                        Hi @peXel,
                        I am happy to help 😉
                        Actually there is one 😉 It even comes with Python. We have also a migration guide.
                        • P Offline
                          peXel
                          That are great news, but sadly I am not a Phyton User
