Preview of a shader...
On 06/09/2003 at 12:13, xxxxxxxx wrote:
Cinema 4D Version: 8.100
Platform: Windows ;
Language(s) : C++ ;---------
I have a noise shader here but have a problem. The shader works fine on the object and the material preview is correct too, but the preview in the AM doesn´t work at all :
The problem is that I am using cd->vd->p as evaluation point of my noise function. When the AM preview is calculated though VolumeData doesn´t seem to be valid so I cannot use it.
So what I can use instead when vd is NULL?
Thank you
Samir -
On 07/09/2003 at 00:53, xxxxxxxx wrote:
If you mean the (new) preview control then you probably should be asking this of sdk_support and not here
On 07/09/2003 at 05:28, xxxxxxxx wrote:
no I am talking about the preview in the AM that is in there since version 8. It´s under the texture group (that´s the name of the gui element I think...) in almost all channels.
Samir -
On 07/09/2003 at 06:07, xxxxxxxx wrote:
ok, got it already
On 07/09/2003 at 19:49, xxxxxxxx wrote:
cd->p is not a coordinate in world or local space but a width and height value in range from 0.0 to 1.0.This value gives you a position on a 2d map . this is the map that you will see in your preview and render. So its 2D texure space and not 3d space.
>If you mean the (new) preview control then you probably should be asking >this of sdk_support and not here
all the more reason for a SDK conference in fc
