    Preview of a shader...
    5 Posts 0 Posters 474 Views
      On 06/09/2003 at 12:13, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      I have a noise shader here but have a problem. The shader works fine on the object and the material preview is correct too, but the preview in the AM doesn´t work at all :
      The problem is that I am using cd->vd->p as evaluation point of my noise function. When the AM preview is calculated though VolumeData doesn´t seem to be valid so I cannot use it.
      So what I can use instead when vd is NULL?
      Thank you
      Samir
        On 07/09/2003 at 00:53, xxxxxxxx wrote:
        If you mean the (new) preview control then you probably should be asking this of sdk_support and not here 😉
          On 07/09/2003 at 05:28, xxxxxxxx wrote:
          no I am talking about the preview in the AM that is in there since version 8. It´s under the texture group (that´s the name of the gui element I think...) in almost all channels.
          Samir
            On 07/09/2003 at 06:07, xxxxxxxx wrote:
            ok, got it already
              On 07/09/2003 at 19:49, xxxxxxxx wrote:
              cd->p is not a coordinate in world or local space but a  width and height value in range from 0.0 to 1.0.This value gives you a position on a 2d map . this is the map that you will see in your preview and render. So its 2D texure space and not 3d space.
              >If you mean the (new) preview control then you probably should be asking >this of sdk_support and not here 😉
              all the more reason for a SDK conference in fc 🙂
