    Unable to Set Priority Data for Skin Deformer
    r21python
    6 Posts 3 Posters 716 Views 2 Watching
    • B Offline
      bentraje
      With the help of this page, I am able to set priority data on a TAG, but not on the SKIN DEFORMER.
      I get a NoneType error. Is there a separate code for setting priority data for the SKIN DEFORMER?
      Here is the code so far:
      def SetPriority(Mode, Value, obj):
          pd=obj[c4d.EXPRESSION_PRIORITY]
          print pd # I get a NONE object here for skin deformer
          pd.SetPriorityValue(c4d.PRIORITYVALUE_MODE, Mode)
          pd.SetPriorityValue(c4d.PRIORITYVALUE_PRIORITY, Value)
          obj[c4d.EXPRESSION_PRIORITY]=pd
          obj = doc.SearchObject("skin_deformer")
          SetPriority(4, 2, obj)
      # Execute main()
        remember the brackets [] return a copy of the BaseContainer.
        You are updating a copy of the data. Either you need to reinject those data to the object or you can use GetDataInstance to retrieve an instance of the BaseContainer.
        But you still need to reinject your data into this BaseContainer.
        def SetPriority(obj, mode, value):
            if obj is None:
                return False
            bc = obj.GetDataInstance()
            if bc is None:
                return False
            pd = bc.GetData(c4d.ID_CA_SKIN_OBJECT_PRIORITY)
            if pd is None:
                print (obj)
                raise ValueError ("can't retrieve expression priority")
            pd.SetPriorityValue( c4d.PRIORITYVALUE_MODE, mode)
            pd.SetPriorityValue( c4d.PRIORITYVALUE_PRIORITY, int(value))
            bc.SetData(c4d.ID_CA_SKIN_OBJECT_PRIORITY, pd)
            obj.Message(c4d.MSG_UPDATE)
            if obj is None:
                raise ValueError("object not found")
            SetPriority(obj, c4d.CYCLE_DYNAMICS,3)
        # Execute main()
        • B Offline
          bentraje
          @m_magalhaes
          Thanks for the clarification. The code works as expected.
          Although I find it weird since the code I posted above (from the Cineversity) works for tags despite using the brackets []
          • B Offline
            bentraje
            Not sure if this would make sense.
            I use the previous code with bracket and just changed obj[c4d.EXPRESSION_PRIORITY] to obj[c4d.ID_CA_SKIN_OBJECT_PRIORITY].
            And it now works as expected.
              you initial code was correct, the only problem was that you used the wrong id. @m_magalhaes probably overlooked the fact that you did write the priority data back (obj[c4d.EXPRESSION_PRIORITY]=pd) and just went for the common mistake in such cases. His version with GetData and SetData is just a bit more verbose and doesn't leave you at the mercy of __getitem__ and __setitem__, i.e. the bracket syntax and also uses the correct id, which "makes it work".
              zipit
                @zipit said in Unable to Set Priority Data for Skin Deformer:
                probably overlooked
                correct, friday evening
