    Remove a GeDialog Tab Group
    Cinema 4D SDK
      A Former User
      I'm trying to remove a GeDialog Tab Group. Is this possible without flushing the Layout and redrawing all of the groups? Thank you
      from c4d import gui
      PLUGIN_ID = 123456
      MAIN_GROUP = 10000
      GROUP_1 = 10001
      GROUP_2 = 10002
      GROUP_BTN = 10003
      TEXT_1 = 2001
      TEXT_2 = 2002
      DELETE_GRP_BTN = 2003
      class MyDialog(c4d.gui.GeDialog):
          def CreateLayout(self):
              self.SetTitle("Remove Group")
              if self.TabGroupBegin(MAIN_GROUP, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, tabtype=c4d.TAB_TABS):
                  if self.GroupBegin(GROUP_1, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 3, 0, "Group 1"):
                      self.GroupBorderSpace(10,10,10,10)
                      self.AddStaticText(TEXT_1, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 0, 0, "Group 1", c4d.BORDER_THIN_IN)
                  self.GroupEnd()
                  if self.GroupBegin(GROUP_2, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 3, 0, "Group 2"):
                      self.AddStaticText(TEXT_2, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 0, 0, "Group 2", c4d.BORDER_THIN_IN)
                  self.GroupEnd()
              self.GroupEnd()
              if self.GroupBegin(GROUP_BTN, c4d.BFH_SCALEFIT | c4d.BFV_BOTTOM, 0, 0, ""):
                  self.AddButton(DELETE_GRP_BTN, c4d.BFH_LEFT, initw=0, inith=0, name='DELETE')
              self.GroupEnd()
          def Command(self, id, msg):
              if id == DELETE_GRP_BTN:
                  self.RemoveElement(GROUP_1)
                  self.LayoutChanged(MAIN_GROUP)
                  #self.SetInt32(MAIN_GROUP, GROUP_2)
          global myDlg
          myDlg = MyDialog()
          myDlg.Open(dlgtype=c4d.DLG_TYPE_ASYNC, xpos=-2, ypos=-2, \
                      pluginid=PLUGIN_ID, defaultw=400, defaulth=350)
      • M
        Hi @blastframe unfortunately, in Python there is no way, and you are right the correct thing is to flush and regenerate all the layout.
        This is for sure not possible in Python, in C++ it may be possible via UpdateDialogHelper.
        If you are interested in a C++ solution I can look further.
          A Former User @m_adam
          @m_adam I'm good with using Python this way. Thanks Maxime.
          • M m_adam referenced this topic on
