    CommandData Plugin with Submenu
    7 Posts 3 Posters 1.6k Views 4 Watching
    • indexofrefractionI Offline
      indexofrefraction
      below is a simple CommandData plugin with a submenu to invoke different actions.
      This works fine if more than one of these plugins (with unique Plugin Ids ofc) are in one plugin folder.
      But there is no menu if there is only one plugin present in the folder.
      Is there a way to create such a menu with one plugin, while not registering each menu point as separate command?
      best index
      # encoding: utf-8
      ''' CommandData Plugin with Menu '''
      PLUGIN_ID = 12345678  # Unique Plugin Id
      MENUID_CMD0 = 1000
      MENUID_CMD1 = 1001
      class MenuHandler(c4d.plugins.CommandData):
      	def Register(self):
      		return c4d.plugins.RegisterCommandPlugin(
      			id=PLUGIN_ID, str="Test", info=c4d.PLUGINFLAG_COMMAND_HOTKEY, icon=None, help=None, dat=MenuHandler())
      	def GetSubContainer(self, doc, submenu):
      		bc = c4d.BaseContainer()
      		bc.SetString(1, "Test")
      		bc.SetString(MENUID_CMD0, "Command 0")
      		bc.SetString(MENUID_CMD1, "Command 1")
      		submenu.InsData(0, bc)
      	def ExecuteSubID(self, doc, id):
      		if id == MENUID_CMD0:
      			pass
      		if id == MENUID_CMD1:
      			pass
      	def Execute(self, doc):
      	MenuHandler().Register()
      • ManuelM Online
        there's currently a bug with this function in python.
        (as i forgot to report in this thread)
          indexofrefraction
          hm, ok...
          but is this bug the reason, that there need to be more than one plugin in a plugin folder to get submenus?
          or in other words ... is it possible to create a submenu in the plugin menu with a single command data plugin?
          index
          • ManuelM Online
            To have a sub menu, you need to register more than one plugin.
            If you add an extra folder (//User/PluginDirectory/Menu) and make cinema4D point to PluginDirectory. An extra level will be created in the menu named in that example Menu.
            Interesting fact. If you register two command, and one have SubID Registered, than the SubID works as expected. (this is obviously a bug)
            If you burry the following code inside a sub folder, the second command will not appear, it's named "---" so should act as a separator. (but there's nothing to separate)
            And you will be able to execute subIDs from the first command.
            I would not do that on a public plugins. This will not work if the user remove that extra folder.
            MAIN_CMD_PLUGIN_ID  = 1055692
            MAIN_CMD_PLUGIN_ID2  = 1055693
            class MYCOMMANDWITHDIALOG (c4d.plugins.CommandData):
            		print ("execute")
            		print ("getsubcontainer", doc, submenu)
            		bc.SetString(1, "Create Primitives")
            		bc.SetString(1000, "Create a cube")
            		bc.SetString(1001, "Create a sphere")
            	def ExecuteSubID(self, doc, subid):
            		print("execute subID", doc, subid)
            		op = None
            		if subid == 1000:
            			 op = c4d.BaseObject(c4d.Ocube)
            		elif subid == 1001:
            			op = c4d.BaseObject(c4d.Osphere)
            		if op is None:
            			return False
            		doc.InsertObject(op)
            class Dummy (c4d.plugins.CommandData):
                c4d.plugins.RegisterCommandPlugin(id=MAIN_CMD_PLUGIN_ID,
                                            str  ="Command with sub id",
                                            info = 0,
                                            help ="Command with sub command or dialog option",
                                            dat = MYCOMMANDWITHDIALOG(),
                                            icon=None)
                c4d.plugins.RegisterCommandPlugin(id=MAIN_CMD_PLUGIN_ID2,
                                            str  ="---",
                                            info = 0,
                                            help ="DummyHiddenCommand",
                                            dat = Dummy(),
                                            icon=None)
            • a_blockA Offline
              a_block
              are there any chances this will ever get fixed?
              Andreas
              • ManuelM Online
                Manuel @a_block
                hi Andreas,
                this is an old bug; I've created a new bug entry trying to describe the problem the best i can. This is not super obvious to understand where to add the fix and what the fix will be.
                • a_blockA Offline
                  a_block
                  Thanks, Manuel
                  I do not mean to stress anybody.
                  But I'd say, this is quiet basic plugin functionality, which by now is not working for more than two years. So, i thought, I'd ask, if there's a chance for a fix.
