    Exception: no converter found for 'net.maxon.interface.url-C[A]'
    4 Posts 3 Posters 932 Views 2 Watching
    • P Offline
      pweisz
      Hello
      I have installed R23 demo.
      I am trying to get the documents List with :
      c4d.documents.GetRecentDocumentsList(isBodyPaint=False)
      but instead of getting the list, I got an exception error printed in the console :
      Is it a bug ?
      P.S.: others c4d.documents methods are working well :
       if doc.GetDocumentName()== "PyRubik":
             pass
              li_docs = c4d.documents.GetRecentDocumentsList(isBodyPaint=False)  **# <-- pb here**
              li_noms = [d.GetDocumentName() for d in li_docs]
              if "PyRubik"  not in li_noms: # create a new doc
                  projet = c4d.documents.BaseDocument()# new doc
                  projet.SetDocumentName("PyRubik")
                  c4d.documents.InsertBaseDocument(projet)
                  c4d.documents.SetActiveDocument(projet)# PyRubik active
                  projet = li_docs[li_noms.index("PyRubik")] # to obtain PyRubik object
                  c4d.documents.SetActiveDocument(projet) # to make "PyRubik" active
      • P Offline
        pweisz
        Hello
        I saw that : c4d.documents.GetRecentDocumentsList(isBodyPaint=False) is for the recent document list but not to get the current document list (opened projects).
        I am not able to find in SDK documentation any method to get the list of opened documents.
        Need help please.
        Patrice
        • r_giganteR Offline
          r_gigante
          Hi Patrice, thanks for reaching out to us.
          With regard to your question, on obtaining the list of opened documents, the solution is pretty easy and consists in getting the first document and iterating over the others.
              activeDoc = c4d.documents.GetFirstDocument()
              while activeDoc is not None:
                  print (activeDoc.GetDocumentName())
                  activeDoc = activeDoc.GetNext()
          Instead with regard to the first issue, you have to include in your script the proper include statement
          import c4d, maxon
          # Main function
              for i in range (li_docs.GetCount()):
                  print (li_docs[i])
          Cheers, R
            without further feedback, we will consider this thread as solved by Wednesday and flag it accordingly.
