    Get the Next Object of doc.SearchObject() Method?
    r21python
    3 Posts 2 Posters 729 Views 1 Watching
    • B Offline
      bentraje
      Is there a way to get the "next" object of doc.SearchObject() method.
      As I understand, if there are two objects name cube. The method will retrieve first cube in the outliner.
      Is there a way to get the next cube object?
      My use case is this:
      1. Check if there are objects with the same name
      2. If there are, throw an error. Every object must have a unique name.
      I guess I can do this with the traversing objects hierarchy code provided by the plugincafe.
      Storing each object name and comparing them with each other.
      But it would be nice if I can just do this with doc.SearchObject so I can shorten the logic.
      Regards,
      Ben
        Hi unfortunately there is nothing built-in so you have to iterate over the scene.
        def HierarchyIterator(obj):
            while obj:
                yield obj
                for opChild in HierarchyIterator(obj.GetDown()):
                    yield opChild
                obj = obj.GetNext()
            names = set()
            for obj in HierarchyIterator(doc.GetFirstObject()):
                objName = obj.GetName()
                if objName not in names:
                    names.add(objName)
                    print("{0} Is already present".format(objName))
        • B Offline
          bentraje
          @m_adam
          Ah gotcha. Thanks for the confirmation and the sample code.
