    Content of PYTHONPATH not appended to sys.path
    pythonwindowsr20
    5 Posts 4 Posters 1.6k Views 4 Watching
      Heinrich Löwe
      Hi, this is my first post in the new forum. I'm exited 😉
      I noticed, that the content of the PYTHONPATH environment variable is not appended to the content of sys.path for the c4d python interpreter. Since we use a lot of site-modules in our company, this issue is rather annoying.
      For the time being I helped myself by updating sys.path during plugin initialization, but I rather would not.
      # extend sys.path whit content of PYTHONPATH
      python_path = os.environ['PYTHONPATH'].replace("\\", "/").split(';')
      for entry in python_path:
          if not entry in sys.path:
              sys.path.append(entry)
      Is there a way to tackle the problem in a more convenient way, like a command line parameter or an environment variable? Is this behavior intended or is it just overlooked during the R20 upgrade process?
      I looking forward to your answers,
      Heinrich.
      • Y Offline
        y_puech
        Hi Heinrich,
        Welcome to the new forum 😀
        PYTHONPATH not added to sys.path is a known issue and has been already fixed for the R20 SP2 update.
        I don't see a better workaround then your with R20 SP1 currently.
        I turned this topic into a Q&A. Please use this functionality in the future. For more information see Q&A New Functionality.
        Former MAXON SDK Engineer
        • bnsB Offline
          bns
          the issue is reappearing in R23.008, I'm wondering if this is a known one.
          thanks in advance,
          ben
            Hi, correct this is a known issue, I should have mentioned in the Changelog, I will update it next week.
            We removed the usage of PYTHONPATH since it's too problematic in case of multiple Cinema 4D versions installed and since PYTHONPATH can be used for a large variety of scripts that could not work in Python 3.7
            bnsB 1 Reply Last reply Reply Quote 1
            • bnsB Offline
              bns @m_adam
              @m_adam thanks for R23.110 C4DPYTHONPATH37 ! ❤
