Hide description element using MessageData::CoreMessage() function
I am aware of hiding elements using NodeData::GetDDescription() function, but I need to hide the elements using MessageData::CoreMessage() function.
My scenario is like this:
I am working on an external renderer, and on my render settings when clicking "Render" Button, I would hide that and show "Abort Render" button instead. I have handled this using NodeData::GetDDescription(), but now when the Rendering is finished I want to Hide "Abort Render" button and instead show "Render" button again.
Since I know when the rendering is finished (Adding a special event with ID = DL_RENDER_FINISHED "SpecialEventAdd(RENDERING_FINISHED);", and I can catch this event using CoreMessage() function, I thought it might possible to hide the elements on this function too.Bool RenderManager::CoreMessage(Int32 id, const BaseContainer &bc) { if (id == RENDERING_FINISHED) { ApplicationOutput("Finished"); //This get's shown exactly after rendering is finished so I know I get the message when I need it. //Need a way to hide an element and show another instead.?? } }
Is there any way I can achieve this?
Thank you. -
it's a bit strange that you are talking about
GetDDescription
witch is forNodeData
andCoreMessage
witch is more about aGeDialog
.If you are inside a
NodeData
you should react to a message received and set a flag and the NodeData dirty.display_aboard = false; node->SetDirty(DIRTYFLAGS::DESCRIPTION);
Setting the node dirty will trigger the
GetDDescription
function and an update of the UI.If you are in a
GeDialog
things are manage with groups and LayoutFlushGroup.Basically you flush the group and recreate it.
We got example of dynamic GeDialog here and also for Descriptions
Manuel -
hi @m_magalhaes
Yes I am talking aboutNodeData
and theCoreMessage
used is notGeDialog::CoreMessage()
but is a MessagePluginMessageData::CoreMessage()
which I am using to receive core messages which in this case are the SpecialEvents I have added when clicking Render Button as in below.Bool RenderSettings::Message(GeListNode* i_node, Int32 i_type, void* i_data) { DescriptionCommand* dc = (DescriptionCommand*)i_data; BaseContainer* dldata = ((BaseVideoPost*)i_node)->GetDataInstance(); switch (i_type) { case MSG_DESCRIPTION_COMMAND: { switch (dc->_descId[0].id) { case RENDER_BUTTON: SpecialEventAdd(START_RENDER); break; //Other cases } } }
Now I am catching this special events using CoreMessage function of MessageData. I am doing this way because I need an event telling me when the rendering is finished and this has nothing to do with a NodeData(Which tells me when the rendering starts) or GeDialog as none of this tells me how long does it take for the rendering to finish.
I do not fully understand what you are trying to do, but @m_magalhaes already gave you the crucial hint IMHO. You can flag your node as description dirty via
and then react there to whatever you want to react to. AFAIK it is impossible to modify a description of a node outside ofGetDDescription
and have these description changes properly reflected in the GUI of the node. So unless I am wrong about this, you won't have any choice but to go this route.Cheers,
zipit -
I'm a bit surprised that your render can be triggered from a NodeData (but why not)
But i don't understand why you can't use GetDDescription to update your node.That's what i did (in a probably too naive way) but you got the idea. I just got a boolean
display_aboard
on my ObjectData and i switch it as i needed.
If i presse the button, i switch and i set dirty my node, if i receive the message that the render is finished (or stopped) i set my bool to false and i SetDirty my node.static const Int32 g_pc12584ButtonID = 1000; class pc12584_object : public ObjectData { INSTANCEOF(pc12584_object, ObjectData); public: static NodeData* Alloc() { return NewObjClear(pc12584_object); }; Bool Init(GeListNode* node) override { display_aboard = false; return true; } BaseObject* GetVirtualObjects(BaseObject* op, HierarchyHelp* hh) override { BaseObject* null = BaseObject::Alloc(Onull); return null; } Bool GetDDescription(GeListNode* node, Description* description, DESCFLAGS_DESC& flags) override { if (!description->LoadDescription(Obase)) return false; const DescID* singleid = description->GetSingleDescID(); const Int32 ID = g_pc12584ButtonID; const DescID cid = DescLevel(ID, DTYPE_BUTTON, 0); if (!singleid || cid.IsPartOf(*singleid, nullptr)) { BaseContainer bc = GetCustomDataTypeDefault(DTYPE_BUTTON); bc.SetInt32(DESC_CUSTOMGUI, CUSTOMGUI_BUTTON); if (display_aboard) bc.SetString(DESC_NAME, "Aboard Render"_s); else bc.SetString(DESC_NAME, "Render"_s); bc.SetInt32(DESC_ANIMATE, DESC_ANIMATE_OFF); bc.SetInt32(DESC_SCALEH, 1); description->SetParameter(cid, bc, DescLevel(ID_OBJECTPROPERTIES)); } flags |= DESCFLAGS_DESC::LOADED; return SUPER::GetDDescription(node, description, flags); } Bool Message(GeListNode* node, Int32 type, void* data) override { switch (type) { case MSG_DESCRIPTION_COMMAND: { DescriptionCommand* dc = (DescriptionCommand*)data; const Int32 id = dc->_descId[0].id; if (id == g_pc12584ButtonID) { display_aboard = !display_aboard; node->SetDirty(DIRTYFLAGS::DESCRIPTION); } break; } case g_pc12584Message: { display_aboard = false; node->SetDirty(DIRTYFLAGS::DESCRIPTION); break; } } return SUPER::Message(node, type, data); }; private: Bool display_aboard = false; }; // function to send a message to the ObjectData. static maxon::Result<void> PC12854_Message(BaseDocument* doc) { iferr_scope; // update the first object BaseObject* op = doc->GetFirstObject(); if (op == nullptr) return maxon::NullptrError(MAXON_SOURCE_LOCATION); op->Message(g_pc12584Message); return maxon::OK; }
