    Python Tag does not update during rendering
    9 Posts 4 Posters 1.4k Views 1 Watching
      marc_angele
      hello c4d guys!
      i have a problem with updating my scene during the rendering. in the viewport it's working. so i don't understand exactly how the scene updating mechanism is working and need help from you experts 🙂
      what i try to do:
      i have a weird alembic camera form maya, with a animated film back offset. the alembic camera in c4d does not interpret this correctly. so i calculated the translation formula and wrote a python script. as i said in the viewport it's doinge exactly what i want, but during rendering it's just frozen on the first frame. i tested it with the c4d.EventAdd() command, but it's still not working. here is my code:
      shotNumber = '0050'
      alembicCam = 'abcCam_' + shotNumber
      standardCam = 'cam_' + shotNumber
          acbCamObj = doc.SearchObject(alembicCam)
          offsetX = acbCamObj[1028637,5103,1118]
          offsetY = acbCamObj[1028637,5103,1119]
          newCam = doc.SearchObject(standardCam)
          newCam[c4d.CAMERAOBJECT_FILM_OFFSET_X] = offsetX * 0.042107036086
          newCam[c4d.CAMERAOBJECT_FILM_OFFSET_Y] = (offsetY * 1.0043387434) * -1
      thanks a lot for any help!
      best,
      marc.
        mp5gosu
        Hi there,
        where do you place your script?
          marc_angele
          i put it in a Python Tag on the new camera.
          • indexofrefractionI Offline
            indexofrefraction
            maybe try
            newCam.Message(c4d.MSG_UPDATE)
            plus maybe
              alembic is a bit strange, this looks like a priority issue but if things gets better increasing the priority of the python tag, it still doesn't work.
              Working inside a Python Generator does seems to work as expected (kind of)
              You can retrieve the "Real Camera" by sending the message MSG_GETREALCAMERADATA to the alembic generator. Example in c++
              It does work but if you open the console, you will see that first (the time the alembic generator generate the camera) it doesn't work twice, but once the Camera is generated it's working. On my test, the render looks ok.
              shotNumber = '0050'
                  if acbCamObj is None:
                      raise ValueError("abc cam not found")
                  # retrieve the alembic real camera
                  data = dict()
                  res = acbCamObj.Message(c4d.MSG_GETREALCAMERADATA, data)
                  if not res:
                      raise ValueError("cannot retrieve the abc camera data")
                  vcam = data['res']
                  if vcam is None:
                      raise ValueError("vcam not found")
                  offsetX = vcam[1118]
                  offsetY = vcam[1119]
                  newCam[c4d.CAMERAOBJECT_FILM_OFFSET_Y] = (offsetY * 1.0043387434) * -1.0
                  print "ok"
                marc_angele
                hi manuel,
                thanks a lot for your answer!
                i'm not sure if i understood it correctly.
                i tested it in my scene, but it didn't work. maybe you can have a short look to my scene?
                thanks a lot!!
                i'm a bit despread, because i have no idea how to solve my problem.
                best,
                marc.
                camtest_v002.c4d
                  Do not use the python tag, use the python generator. (Create -> Generator -> Python Generator)
                    marc_angele
                    manuel, you are my hero!
                    thanks a lot! it is working 🙂
                    sorry, i totally missed the point with the python generator.
                    i never used the generator before, i always used the tag.
                    what is the difference? when should i use the tag and when the generator?
                    thank you again!
                    marc.
                      we got some information in our documentation.
                      For example you can't add an object in the document from a tag while the generator can return a hierarchy.
                      But you can easily draw information on the viewport with a tag.
