    set sculpting layer data from high resolution mesh.
    3 Posts 2 Posters 681 Views 1 Watching
    • J Offline
      jeongseok
      Hello.
      I want to sculpting from high mesh.
      High mesh was got from zbrush.
      this is like 'Project Mesh'.
      My code is simple but was not working.
      from c4d.modules import sculpting
          sculpt = sculpting.GetSelectedSculptObject(doc)
          sel = doc.GetActiveObject()
          if not sculpt:
          if not sel:
          if sel == sculpt.GetOriginalObject():
          if sculpt.GetPointCount() != sel.GetPointCount():
          firstLayer = sculpt.GetFirstLayer()
          layer = firstLayer.GetFirstSculptLayer()
          for i in range(firstLayer.GetPointCount()):
              layer.SetOffset(i, sel.GetPoint(i))
          sculpt.Update()
      Traceback (most recent call last):
      File "scriptmanager", line 26, in <module>
      File "scriptmanager", line 21, in main
      TypeError: an integer is required
      SculptLayer.SetOffset(self, index, offset)
      offset is vector. but 'TypeError: an integer is required'
      how can i fix it?
      Thank you.
      sculpting _error.c4d
        There's actually a bug in the API, not only this method is affected. It probably affect all method of the sculpt module using a vector as a parameter.
        This will be fixed as soon as possible.
        J 1 Reply Last reply Reply Quote 2
        • J Offline
          jeongseok @Manuel
          @m_magalhaes Thank you for reply. I am going to use it for this project. Hope it gets fixed soon. Thank you.
