    Mouse positions and screen dimensions
    r20r21c++
    17 Posts 3 Posters 3.1k Views 3 Watching
    • C4DSC Offline
      C4DS @Manuel
      @m_magalhaes said in Mouse positions and screen dimensions:
      But no news 🙂
      Thanks for the update. I guess no news is good news ...
      • C4DSC Offline
        C4DS
        Hi again,
        It is not my intention to bump this topic every other day, but I just want to know if a response from devs is still in the pipeline.
        So far, it seems that with R21 the obtained mouse coordinates are valid as long as the mouse pointer is hovering over the main Cinema application window. Once outside of that window the obtained coordinates are that of the last position inside the window.
        This means that when the application is not full screen, or when multiple monitors are involved the coordinates outside of the window are useless. Most important is that one cannot find out if the mouse cursor is inside or outside the window and thus decide (or know) the obtained values are useless.
        This isn't an issue with R20.
        On the other hand, as far as I have understood with the release of S22, there will be no further service packs for R21. Which means any fix to this issue (if provided) will be S22 or R22.
        Which brings me to the inevitable decision that I will need to ditch any further development for R21. There just are too many unresolved open issues for any of my current (and work-in-progress) plugins.
          no problem to bump it.
          But still no news.
          • C4DSC Offline
            C4DS
            I am starting to lose hope we'll ever say any update/answer on this topic.
            And as a result I am close to giving up on further R21 development. And beyond.
            For me, there are just too many open issues that don't get resolved (this one included). The cost for finding workarounds, or alternative solutions is just becoming too high, and not worth the effort anymore.
              I apologie for the delay here.
              you will have an answer for sure, maybe not the one you are waiting for, but you will have one.
              I was going to talk about that in our daily meeting anyway, but thanks for bumping it again, we asked the dev again 🙂
                After talking with dev and few tests:
                • Mouse data could be outdated when you were calling a command Data via a shortcut. This bug will be fixed in the next update.
                • GetInputState return coordinate in local to the editor windows space, not in screen space. But this should be used with caution and should probably be used only for keyboard modifier checks.
                • GetScreenDimensions This was a bit hard to understand what was going on, i must say that i wasn't expecting that.
                  First, the coordinates are relatives to the main display. (not the 1st display, but the display set as "main").
                  as the mouse coordinates wasn't really helpfull you can "force them" to 0,0 and -10,-10
                This is my setup and the monitor 2 is in fact my main display.
                0,0 will return 0,0 / 2560, 1440
                -10,-10 will return -491, 2069 / -1440, 0
                and that does make.
                • C4DSC Offline
                  C4DS @Manuel
                  Thanks for the detailed response.
                  Are we still talking R21, or will this be R22?
                  If GetInputSate is not to be used to obtain the mouse coordinates, what would be the better way to get the mouse position?
                    @C4DS said in Mouse positions and screen dimensions:
                    it's not a stop seller so it will be probably fixed in R23.
                    Well this is the global function, in a GeDialog you should use GeDialog::GetInputState
                    I need to check the real differences to answer with more details sorry. This is something we need to talk about and document a bit more.
                    Not the answer you were waiting for i know.
                    C4DSC 2 Replies Last reply Reply Quote 0
                    • C4DSC Offline
                      C4DS @Manuel
                      Oh, I read "the next update" as being "the update right around the corner".
                      Not as if someone saying "the next day" but actually meaning "in a not to near future".
                      But thanks for pointing it out.
                      Sorry, I am not in context of a GeDialog, but a CommandData.
                      What other options than the global function do I have here?
                      True, not really the answer I was looking for, but still grateful for the reply. Thank you for that.
                      • C4DSC Offline
                        C4DS @Manuel
                        Any news or additional info to share on this?
                          sorry, it get out of my mind.
