    Directory UI component ?
    2 Posts 2 Posters 613 Views 1 Watching
    • N Offline
      nicholas_yue
      I am reading the following
      https://developers.maxon.net/docs/py/2023_2/modules/c4d.gui/GeDialog/index.html?highlight=addeditnumberarrows#GeDialog.AddEditText
      hoping there might be some directory browsing UI.
      My intention is to allow the user to pick an output directory for some processing.
        Hi @nicholas_yue this can be done with the CUSTOMGUI_FILENAME
        Here a complete example
        class ExampleDialog(c4d.gui.GeDialog):
            def CreateLayout(self):
                This Method is called automatically when Cinema 4D Create the Layout (display) of the Dialog.
                settings = c4d.BaseContainer()
                settings[c4d.FILENAME_DIRECTORY] = True
                self.AddCustomGui(1000,
                                  c4d.CUSTOMGUI_FILENAME, "",
                                  c4d.BFH_SCALEFIT | c4d.BFV_CENTER, 0, 0, settings)
                # Creates a Ok and Cancel Button
                self.AddDlgGroup(c4d.DLG_OK | c4d.DLG_CANCEL)
            def Command(self, messageId, bc):
                This Method is called automatically when the user clicks on a gadget and/or changes its value this function will be called.
                It is also called when a string menu item is selected.
                :param messageId: The ID of the gadget that triggered the event.
                :param bc: The original message container
                :return: False if there was an error, otherwise True.
                # User changed the file path
                if messageId == 1000:
                    print(self.GetFilename(1000))
                # User click on Ok button
                if messageId == c4d.DLG_OK:
                # User click on Cancel button
                elif messageId == c4d.DLG_CANCEL:
                    print("User Click on Cancel")
                    # Close the Dialog
                    self.Close()
            # Creates a new instance of the GeDialog
            dlg = ExampleDialog()
            # Opens the GeDialog, since it's open it as Modal, it block Cinema 4D
            dlg.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE, defaultw=300, defaulth=50)
