    Unable to update Alembic path in xref
    Cinema 4D SDK
    1.2k
    • N
      nicholas_yue
      I have the following code which was able to get the path but can't update the path
      flags = c4d.SCENEFILTER_MERGESCENE | c4d.SCENEFILTER_OBJECTS | c4d.SCENEFILTER_MATERIALS
      active_doc = c4d.documents.GetActiveDocument()
      merge_status = c4d.documents.MergeDocument(active_doc, target_scene, flags)
      assert(merge_status)
      # Model[c4d.ID_CA_XREF_FILE]
      obj_name_to_search = 'Model'
      xref = active_doc.SearchObject(obj_name_to_search)
      alembic_path = xref.GetParameter(c4d.ID_CA_XREF_FILE, c4d.DESCFLAGS_GET_NONE)
      print(alembic_path)
      status = xref.SetParameter(c4d.ID_CA_XREF_FILE, animated_alembic_file, c4d.DESCFLAGS_SET_PARAM_SET)
      assert(status)
      if True:
          c4d.documents.SaveDocument(active_doc,
                                  target_scene,
                                  c4d.SAVEDOCUMENTFLAGS_0,
                                  c4d.FORMAT_C4DEXPORT)
      • r_giganteR
        r_gigante
        Hi @nicholas_yue , thanks for reaching out us.
        With regard to your question please be aware that C4DAtom::SetParameter() has to be called with DESCFLAGS_SET_USERINTERACTION flag to set ID_CA_XREF_FILE.
        Best, Riccardo
        • N
          nicholas_yue
          @r_gigante said in Unable to update Alembic path in xref:
          Using DESCFLAGS_SET_USERINTERACTION there was a prompt in my script.
          Update XRef (Yes) or replace (No)?
          How do I respond (Yes) in my script ?
          • M
            Unfortunately, there is no built-in way to control MessageBox within Cinema4D.
            The only way for you is to install a 3rd party python package, here a possible one https://github.com/asweigart/pyautogui.
            N 1 Reply Last reply Reply Quote 0
            • N
              nicholas_yue @m_adam
              @m_adam said in Unable to update Alembic path in xref:
              But I am running the script with c4dpy, there is no UI.
              Is there something I can call in c4dpy to tell the current active session to default to "Yes", it seems that c4dpy defaults to "No"
              • M
                I know, it's not what you expected but there is for the moment no way to automate this using Cinema 4D API.
