    SnapCore and Intersect
    4 Posts 2 Posters 882 Views 1 Watching
    • RenatoTR Offline
      RenatoT
      Hi all,
      I tried the code described in this thread: https://developers.maxon.net/forum/topic/6626/7199_r14-snap-system/10
      This code inside the liquitool example work as expected.
      But if i try to use SnapCore::Intersect instead SnapCore::Snap, to get the normal at point, this code don't work.
      This is the line that I changed to:
      if (snap->Intersect(pos, norm, false, res)) instead if (snap->Snap(pos, res))
      Seem that the intersection don't work anymore.
      Any help?
      Thanks in advance
      Renato T.
      Real mx = msg.GetReal(BFM_INPUT_X);
      Real my = msg.GetReal(BFM_INPUT_Y);
      LONG button;
      switch (msg.GetLong(BFM_INPUT_CHANNEL))
          case BFM_INPUT_MOUSELEFT : button=KEY_MLEFT; break;
          case BFM_INPUT_MOUSERIGHT: button=KEY_MRIGHT; break;
          default: return TRUE;
      AutoAlloc<SnapCore> snap;  // Allocate snap
      if (!snap) return FALSE;
      snap->Init(doc, bd);
      Real dx, dy;
      BaseContainer bc;
      BaseContainer device;
      Vector pos;
      SnapResult res;
      BaseObject *active = doc->GetActiveObject();
      win->MouseDragStart(button, mx, my, MOUSEDRAGFLAGS_DONTHIDEMOUSE|MOUSEDRAGFLAGS_NOMOVE);
      while (win->MouseDrag(&dx,&dy,&device)==MOUSEDRAGRESULT_CONTINUE) // Start drag
          // Increment mouse position during drag
          mx += dx;
          my += dy;
          pos = bd->SW(Vector(mx, my, 500)); // Update pos
          if (snap->Snap(pos, res)) // If point snap anywhere
              pos += res.delta; // Pos will be updated with snapped delta
          if (active)
              active->SetAbsPos(pos); // Set the object position to the new one!
          DrawViews(DRAWFLAGS_ONLY_ACTIVE_VIEW|DRAWFLAGS_NO_THREAD|DRAWFLAGS_NO_ANIMATION); // Update viewport
      win->MouseDragEnd(); // Reset viewport status
      EventAdd();
      • RenatoTR Offline
        RenatoT
        Seem that the normal is returned by SnapCore::Snap in SnapResult::mat.v2. I'm verifying
          Hi @RenatoT, I don't think there is an issue,
          just in case Intersect is supposed to work only for guide and spline see Modeling Settings - Intersection Snap. So maybe you are looking for GeRayCollider::Interesct.
          • RenatoTR Offline
            RenatoT
            Hi Maxime. Thanks for reply. At last I used the BVHTree for that.
