    XRef : Alembic pop-up suppression ?
    5 Posts 2 Posters 908 Views 1 Watching
    • N Offline
      nicholas_yue
      I created a couple of XRef that load alembic file. When I re-open the C4D file, I get a pop-up for each alembic file. How can I suppress the Alembic pop-up as I plan to build a large scene with many XRef and don't want the artists to click OK for every alembic file in the scene.
        i couldn't reproduce the issue here, are you loading the alembic with a script or a python generator ?
        • N Offline
          nicholas_yue
          I am creating the xRef from the UI
            If you are not doing anything related to programming, you must use our support : https://support.maxon.net/index.php?lang=en_US
            This is the support forum where you can find help related to programming for Cinema 4D.
            (by the way, is that the same if you are using the add xref command and not using the object ?)
            • N Offline
              nicholas_yue
              OK, I will use the support forum.
              Yes, using "Add XRef..." still result in seeing the Alembic Settings pop up every time I open the file.
