Sizing Plugin Dialogs
In a previous post, How to open a GeDialog Modal to default width & height? the solution to thedefaultw/defaulthbug for a script Modal was to pass thepluginid. I am trying this solution with a Command Plugin and I'm not getting the specified sizes for either window. I thought maybe it has to do with thesubidbut my Main Dialog isn't behaving either.Here is some test code I'm using:
import c4d from c4d import documents, gui, plugins PLUGIN_ID = 1055306 #test id ANOTHER_DLG_ID = 5000 class AnotherDlg(gui.GeDialog): MY_TEXT = 1000 def CreateLayout(self): self.SetTitle("Another Dialogue") self.AddStaticText(self.MY_TEXT, c4d.BFH_CENTER | c4d.BFH_SCALE, name="Another Dialog",inith=40) return True class MyDlg(gui.GeDialog): MY_BUTTON = 1000 def __init__(self): global anotherDialog self.anotherDialog = AnotherDlg() def CreateLayout(self): self.SetTitle("Test") self.AddButton(self.MY_BUTTON, c4d.BFH_CENTER | c4d.BFH_SCALE | c4d.BFV_CENTER | c4d.BFV_SCALE, initw=0, inith=0, name="Open Dialog") return True def Command(self, id, msg): if id == self.MY_BUTTON: self.anotherDialog.Open(c4d.DLG_TYPE_MODAL, pluginid=PLUGIN_ID, subid=ANOTHER_DLG_ID, xpos=-2, ypos=-2, defaultw=600, defaulth=150) return True def Restore(self, pluginid, secref): if secref['subid'] == ANOTHER_DLG_ID: return self.anotherDialog.Restore(pluginid, secref) else: return super(MyDlg, self).Restore(pluginid, secref) class MyData(c4d.plugins.CommandData): dialog = None def Execute(self, doc): if self.dialog is None: self.dialog = MyDlg() global myDlg myDlg = self.dialog return myDlg.Open(dlgtype=c4d.DLG_TYPE_ASYNC, xpos=-2, ypos=-2, pluginid=PLUGIN_ID, defaultw=700, defaulth=300) def RestoreLayout(self, sec_ref): if self.dialog is None: self.dialog = MyDlg() global myDlg myDlg = self.dialog return myDlg.Restore(pluginid=PLUGIN_ID, secref=sec_ref) if __name__ == "__main__": plugins.RegisterCommandPlugin(id=PLUGIN_ID, str="Test", info=0, help="Test", dat=MyData(), icon=None)Here are the results:
The Main Dialog (
DLG_TYPE_ASYNC) is 324x51 and the secondary dialog (DLG_TYPE_MODAL) is 324x100. This is making layout difficult.Can anyone please help me to get these to open to the specified sizes? Thank you!
UPDATE:
I'm thinking that the Main Dialog cannot be resized as it isDLG_TYPE_ASYNC. The secondary Dialog is taking the width from the last dragged dimensions of the Main Dialog.I'm not sure if this is correct, but I was able to get the dimensions I needed for the secondary GeDialog by giving it a unique PLUGIN_ID and removing the subid (code below).
self.anotherDialog.Open(c4d.DLG_TYPE_MODAL, pluginid=ANOTHER_DLG_ID, xpos=-2, ypos=-2, defaultw=600, defaulth=450)Do I need to create a unique PLUGIN_ID for every GeDialog or is there another way?
Hi @blastframe thanks for writing us.
Yes, as stated in your second post having unique ids for the different dialog is the safer way to prevent unexpected behavior like the one reported initially. Tested successfully (both main (async) dialog and modal dialog were correctly sized and placed on mac and windows) I also confirm there's no need to specify the
subid.
Best, R
Hi @r_gigante, thank you for the reply!
With regards to the
DLG_TYPE_ASYNC, the GeDialog size has not always worked consistently for me. Is Cinema 4D storing information for when the Async GeDialogs have been resized? If so, is there a way to clear this preference? Thanks! -
Hi @blastframe, I apologize for having left this thread unanswered for such a long time and I hope it still meaningful to you getting answered.
I confirm that Cinema 4D indeed stores such information, but the BaseContainers used are not accessible from the outside and you can't modify their data.
Can you provide us an example to reproduce the lack of consistency you mentioned?
Cheers, R
without further feedback, we will consider this thread as solved by Wednesday and flag it accordingly.
Ferdinand -
Hi team, thanks for the replies. Like you I'm sure, I've been very busy since the initial topic was created six months ago and don't have any examples on hand. I'll keep my eyes open for them in future projects though and post if I can reproduce. Thanks.
Hi @blastframe,
this was not request for you to get work, but simply part of our support management. People often forget that they have posted a "Ask-as-question"-topic and we have to deal with these cases somehow. I interpret your answer in that way, that you still have questions, but hadn't time yet to tackle them, right? Then I will leave this question open for now.
Ferdinand -
Hi @blastframe,
without further questions or feedback, by Monday we will consider this thread as solved and flag it accordingly.
