    How to create a layer Reflection (Legacy) ?
    2 Posts 1 Posters 994 Views 1 Watching
    • KantroninK Offline
      Kantronin
      Hi
      I created a material.
      I inserted a texture into the COLOR channel.
      Then, I inserted another texture into the BUMP channel.
      Now, I want to insert a texture for the specularity, but I don't know how to create a Layer Reflection (Legacy)
      I only activated the REFLECTANCE channel with the following code:
      mat [c4d.MATERIAL_USE_REFLECTION] = True
      Then I want to apply the following values for this layer:
      0.5 for REFLECTION_LAYER_MAIN_VALUE_ROUGHNESS
      1.0 for REFLECTION_LAYER_MAIN_VALUE_REFLECTION
      0.2 for REFLECTION_LAYER_MAIN_VALUE_SPECULAR
      1.0 for REFLECTION_LAYER_MAIN_VALUE_BUMP
      I suppose that these values must be prefixed by the variable 'mat' which represents the material and also by the id of the layer.
        Kantronin
        I found the solution to my problem, on the internet, with code samples:
        https://www.c4dcafe.com/ipb/forums/topic/101805-materials-and-shaders-with-python/
