    How to Communicate between SubDialog and main GeDialog
    s22pythonsdk
    5 Posts 2 Posters 824 Views 2 Watching
    • ? Offline
      A Former User
      I am trying to send messages from a SubDialog to a parent GeDialog. I am using a variation of this example implementation from NiklasR.
      PLUGIN_ID = 1000004 # Test ID
      ACTION_ID = 123456
      class MainDialog(c4d.gui.GeDialog):
          @property
          def sub_dialog(self):
              if not hasattr(self, '_sub_dialog'):
                  self._sub_dialog = SubDialog()
              return self._sub_dialog
          def CreateLayout(self):
              self.SetTitle('Main Dialog')
              self.AddButton(1000, 0, name="Open Sub-Dialog")
          def Message(self, msg, result):
              if msg.GetId() == ACTION_ID:
                  print msg
              return c4d.gui.GeDialog.Message(self, msg, result)
          def Command(self, param, bc):
              print bc
              if param == 1000:
                  self.sub_dialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=1)
          def Restore(self, pluginid, secref):
              if secref['subid'] == 1:
                  return self.sub_dialog.Restore(pluginid, secref)
                  return super(MainDialog, self).Restore(pluginid, secref)
      class SubDialog(c4d.gui.GeDialog):
              self.SetTitle('Sub-Dialog')
              self.AddButton(1000, 0, name="Send Message")
          def Command(self, id, msg):
              if id == 1001:
                  bc = c4d.BaseContainer()
                  bc.SetId(c4d.BFM_ACTION)
                  bc.SetInt32(c4d.BFM_ACTION_ID, ACTION_ID)
                  self.SendParentMessage(bc)
      class Command(c4d.plugins.CommandData):
          def Register(self):
              return c4d.plugins.RegisterCommandPlugin(
                      PLUGIN_ID, "Sub-Dialog Message", 0, None, "", self)
          @property
          def dialog(self):
              if not hasattr(self, '_dialog'):
                  self._dialog = MainDialog()
              return self._dialog
          def Execute(self, doc):
              return self.dialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID)
          def RestoreLayout(self, secref):
              return self.dialog.Restore(PLUGIN_ID, secref)
          Command().Register()
      I've tried using SendParentMessage but, for whatever reason, my parent dialog isn't receiving the message.
      In my parent GeDialog I've tried using the Command and Message methods, but neither receives the message from the SubDialog.
      Can anyone help? Thank you!
        Hi @blastframe the main issue I guess is because of your SubDialog inherit from GeDial and not SubDialog.
        Here a quick example
        GADGET_ID_SUBDIALOG = 10000
        MSG_ID_SUBDIALOG_LAYOUT_CREATED = 1000001
        class SubDialogExample(c4d.gui.SubDialog):
                This Method is called automatically when Cinema 4D Create the Layout (display) of the SubDialog.
                # Creates a Static Text
                self.AddStaticText(1000, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 0, 0, "First Sub Dialog", c4d.BORDER_THIN_IN)
                msgContainer = c4d.BaseContainer(MSG_ID_SUBDIALOG_LAYOUT_CREATED)
                self.SendParentMessage(msgContainer)
        class ExampleDialog(c4d.gui.GeDialog):
            # The SubDialog need to be stored somewhere, we will need this instance to be attached to the current Layout
            subDialog = SubDialogExample()
                This Method is called automatically when Cinema 4D Create the Layout (display) of the Dialog.
                # Adds a Gadget that will host a SubDialog
                self.AddSubDialog(GADGET_ID_SUBDIALOG, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 100, 100)
                # Attaches the stored SubDialog to the Gadget previously created
                self.AttachSubDialog(self.subDialog, GADGET_ID_SUBDIALOG)
                This Method is called automatically when the GeDialog receives a Message.
                :param msg: The message container.
                :param result: A container to place results in.
                # Messages is sent from the GeUserArea in line 65
                if msg.GetId() == MSG_ID_SUBDIALOG_LAYOUT_CREATED:
                    print("The GeUserArea, has been draw.")
                return super(ExampleDialog, self).Message(msg, result)
            # Creates a new instance of the GeDialog
            dlg = ExampleDialog()
            # Opens the GeDialog, since it's open it as Modal, it block Cinema 4D
            dlg.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE, defaultw=300, defaulth=50)
        • ? Offline
          A Former User @m_adam
          @m_adam Hi Maxime, thank you for the reply.
          I wasn't able to get it to work. I would like the Subdialog to be its own window, not attached to the Main Dialog. Is this possible? In the documentation for SendParentMessage it says the method is available for GeDialog but is it only for usage with GeUserArea? I don't think I understand the purpose of the Subdialog when used as a gadget. I see in the documentation for Subdialog that it inherits from GeDialog so shouldn't it be able to open as such? Thank you.
          ACTION_ID = 123456
          class SubDialog(c4d.gui.SubDialog):
                  self.AddButton(1001, 0, name="Send Message")
                  if id == 1001:
              subDialog = SubDialog()
                  #self.AddSubDialog(GADGET_ID_SUBDIALOG, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 100, 100)
                  #self.AttachSubDialog(self.subDialog, GADGET_ID_SUBDIALOG)
                      print "YES"
                  print bc
                  if param == 1000:
                      self.subDialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=1)
                      return self.subDialog.Restore(pluginid, secref)
              def Register(self):
              @property
              def dialog(self):
                  return self._dialog
            Did you try my example which exactly demonstrate the use of a SubDialog?
            SubDialog is about having a dialog embedded into another one.
            If you want to make communicate two independent GeDialog you have to use CoreMessage because there is no hierarchy between them they are both independent windows.
            • ? Offline
              @m_adam Hi Maxime, I did try your example and I saw it working as a gadget but, you're right, I want to communicate between two GeDialogs. I followed your advice on using CoreMessage and found success with SpecialEventAdd. Thank you!
