    Draw HUD-like text to viewport
    r21classic api
    12 Posts 4 Posters 2.8k Views 2 Watching
    • fwilleke80F Offline
      fwilleke80
      Hi & thank you for the reply!
      That is, I guess pretty much what I do. Only you are copying alpha values from another BaseBitmap, and I need to make up alpha values based on the color of pixels in the BaseBitmap I got from the GeClipMap. As long as my alpha values are in the range of 0 ... 255 (which they are), I should see at least some kind of semi transparency, right?
      So, my question remains 😄 Maybe the SDK team knows some details?
      Thanks & greetings,
      Frank
      www.frankwilleke.de
        Maybe I am misunderstanding something, but you were talking about BaseBitmap::AddChannel, which will add an additional alpha channel as supported by the psd or tif format for example. BaseBitmap::SetAlphaPixel will write to the primary alpha channel as supported by many image formats. So there is a major difference between @C4DS's and your code.
        zipit
          fwilleke80
          Oh, ok. As far as I understood the docs, BaseBitmap::AddChannel() would add an alpha channel, and passing true as the first argument would make this the "internal" alpha channel. After all, before I can set any alpha value with BaseBitmap::SetAlphaPixel() I would need an alpha channel to set the data to, right? BaseBitmap::GetInternalChannel() gives me nullptr if I don't call BaseBitmap::AddChannel() first.
          And no, as I see it, BaseBitmap::SetAlphaPixel() does not always write to the primary alpha channel, but to the channel I pass to the function. If I pass nullptr, no alpha value seems to be written.
          www.frankwilleke.de
            ferdinand @fwilleke80
            @fwilleke80 said in Draw HUD-like text to viewport:
            You are absolutely right, sorry, I did not read your posting carefully enough. But I also have drawn a bitmap to viewport with the approach shown by @C4DS, so it still might be worth a try.
            Cheerss,
            zipit
              fwilleke80
              But that is how I am doing it, too. Using BaseBitmap::SetAlphaPixel() to set alpha values into the bitmap's internal alpha channel. I am getting my values from another source (because I'm not copying a bitmap, but creating a new one), but they are still in the correct value range. I have even tried setting all pixels to the same alpha value (e.g. 128) and still did not get a semi transparent result in the viewport.
              www.frankwilleke.de
                fwilleke80
                Hm... interesting. I am getting a promising result now with this code:
                BaseBitmap* MyClass::CreateTextBitmap(const String &text, const Vector &textColor, const Vector &bgColor, Float bgOpacity, Int32 margin)
                	if (!_clipmap)
                		_clipmap.Assign(GeClipMap::Alloc());
                		if (!_clipmap)
                			return nullptr;
                	// Dummy draw, just to get the text dimensions
                	if (_clipmap->Init(0, 0, 32) != IMAGERESULT::OK)
                		return nullptr;
                	_clipmap->BeginDraw();
                	Int32 width = _clipmap->GetTextWidth(text) + margin * 2;
                	Int32 height = _clipmap->GetTextHeight() + margin * 2;
                	_clipmap->EndDraw();
                	_clipmap->Destroy();
                	// Begin actual drawing
                	if (_clipmap->Init(width, height, 32) != IMAGERESULT::OK)
                		return nullptr;
                	width = _clipmap->GetBw();
                	height = _clipmap->GetBh();
                	// Background. Fill clipmap with a rectangle, overpainting possibly existing text
                	// Drawn with alpha = 255, because this alpha value just defines the transparency of the drawn color over the background.
                	// The actual background alpha is set later.
                	const Int32 backgroundColorR = (Int32)(bgColor.x * 255.0);
                	const Int32 backgroundColorG = (Int32)(bgColor.y * 255.0);
                	const Int32 backgroundColorB = (Int32)(bgColor.z * 255.0);
                	_clipmap->SetColor(backgroundColorR, backgroundColorG, backgroundColorB, 255);
                	_clipmap->FillRect(0, 0, width - 1, height - 1);
                	const Int32 backgroundOpacity = (Int32)(bgOpacity * 255.0);
                	// Text
                	_clipmap->SetColor((Int32)(textColor.x * 255.0), (Int32)(textColor.y * 255.0), (Int32)(textColor.z * 255.0), 255);
                	_clipmap->TextAt(margin, margin, text);
                	BaseBitmap *bitmap = _clipmap->GetBitmap()->GetClone();
                	if (!bitmap)
                		return nullptr;
                	BaseBitmap *alphaBitmap = bitmap->AddChannel(true, true);
                	if (!alphaBitmap)
                		return nullptr;
                	alphaBitmap = bitmap->GetInternalChannel();
                	if (!alphaBitmap)
                		return nullptr;
                	for (Int32 y = 0; y < bitmap->GetBh(); ++y)
                		for (Int32 x = 0; x < bitmap->GetBw(); ++x)
                			// 100% transparent corners
                			if ((x == 0 && y == 0) || (x == width - 1 && y == height - 1) ||
                				(x == 0 && y == height - 1) || (x == width - 1 && y == 0))
                				bitmap->SetAlphaPixel(alphaBitmap, x, y, 0);
                			else // All other pixels: semi transparent
                				bitmap->SetAlphaPixel(alphaBitmap, x, y, backgroundOpacity);
                	return bitmap;
                I wonder why this looks so different... I still didn't set opaque pixels for the text, but it seems to be a good start...
                www.frankwilleke.de
                  fwilleke80
                  What I also find weird is, that even if I use the DrawMultipleHUDText() function, the stuff that appears in the viewport still looks different from the standard HUD elements like "Projection" or "FPS". It's a bit darker and the margin around the text looks different.
                  www.frankwilleke.de
                  • r_giganteR Offline
                    r_gigante
                    Hi Frank, thanks for reaching out us.
                    I've played a bit with and I came to this other solution which make no use of BaseBitmap and should provide more coherent results UI-wise.
                    Looking forward checking how it compares with regard to performances.
                    maxon::Result<void> OptimizedDrawMultipleHUDText(const maxon::BaseArray<HUDTextEntry>& texts, BaseDraw* bd)
                    	if (!bd || texts.IsEmpty())
                    		return maxon::IllegalArgumentError(MAXON_SOURCE_LOCATION);
                    	AutoAlloc<GeClipMap> bgClipMap;
                    	if (!bgClipMap)
                    		return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION);
                    	AutoAlloc<GeClipMap> clipMap;
                    	if (!clipMap)
                    	// get the current view region
                    	Int32 cr, cl, cb, ct;
                    	bd->GetFrame(&cl, &ct, &cr, &cb);
                    	// calculate view sizes
                    	const Int32 viewW = (cr - cl + 1);
                    	const Int32 viewH = (cb - ct + 1);
                    	// set the BaseDraw matrix and lighting method
                    	bd->SetMatrix_Screen();
                    	bd->SetLightList(BDRAW_SETLIGHTLIST_NOLIGHTS);
                    	// Init HUD clipmap
                    	if (clipMap->Init(viewW, viewH, 32) != IMAGERESULT::OK)
                    		return maxon::UnexpectedError(MAXON_SOURCE_LOCATION);
                    	clipMap->BeginDraw();
                    	const Vector 	textColor = 255 * bd->GetParameterData(BASEDRAW_HUD_TEXTCOLOR).GetVector();
                    	const Vector 	bgColor = 255 * bd->GetParameterData(BASEDRAW_HUD_BACKCOLOR).GetVector();
                    	const Float 	bgTransparency = 255 * bd->GetParameterData(BASEDRAW_HUD_BACKOPACITY).GetFloat();
                    	const Int32 textH = clipMap->GetTextHeight();
                    	const Int32	drawH = textH + 10;
                    	const Int32 tX = 5;
                    	const Int32	tY = (drawH - textH) / 2;
                    	// set the complete image transparent
                    	clipMap->SetColor((Int32)bgColor.x, (Int32)bgColor.y, (Int32)bgColor.z, 0);
                    	clipMap->FillRect(cl, ct, cr, cb);
                    	for (const auto& it : texts)
                    		// get text sizes
                    		const Int32 textW = clipMap->GetTextWidth(it._txt);
                    		const Int32 drawW = textW + 10;
                    		// init BG clip
                    		if (bgClipMap->Init(drawW, drawH, 32) != IMAGERESULT::OK)
                    		// create the BG
                    		bgClipMap->BeginDraw();
                    		bgClipMap->SetColor((Int32)bgColor.x, (Int32)bgColor.y, (Int32)bgColor.z, (Int32)bgTransparency);
                    		bgClipMap->FillRect(0, 0, drawW, drawH);
                    		bgClipMap->EndDraw();
                    		// blit BG
                    		clipMap->Blit((Int32)it._position.x, (Int32)it._position.y, *bgClipMap, 0, 0, drawW, drawH, GE_CM_BLIT::COL);
                    		// set text color
                    		clipMap->SetColor((Int32)textColor.x, (Int32)textColor.y, (Int32)textColor.z, 255);
                    		// draw Text
                    		clipMap->TextAt((Int32)it._position.x + tX, (Int32)it._position.y + tY, it._txt);
                    	clipMap->EndDraw();
                    	// set the points coordinates
                    	const Vector 	pvText[4] = {
                    		Vector((Float)cl, (Float)ct, 0),
                    		Vector((Float)cl, (Float)ct, 0) + Vector(viewW, 0.0, 0.0),
                    		Vector((Float)cl, (Float)ct, 0) + Vector(viewW, viewH, 0.0),
                    		Vector((Float)cl, (Float)ct, 0) + Vector(0.0, viewH, 0.0)};
                    	// set the UVs coordinates
                    	const Vector 	pvUV[4] = {
                    		Vector(0, 0, 0),
                    		Vector(1, 0, 0),
                    		Vector(1, 1, 0),
                    		Vector(0, 1, 0)};
                    	// draw in Viewport
                    	bd->DrawTexture(clipMap->GetBitmap(), pvText, nullptr, nullptr, pvUV, 4, DRAW_ALPHA::NORMAL, DRAW_TEXTUREFLAGS::INTERPOLATION_NEAREST | DRAW_TEXTUREFLAGS::TEMPORARY);
                    	return maxon::OK;
                    Best, R
                      fwilleke80
                      Thank you Ricardo! This looks much simpler than the code we're currently using. I'll check it out!
                      www.frankwilleke.de
                        fwilleke80
                        Hm, not bad. In deed, it has the potential to look more like the "normal" HUD, without doing hacky stunts. And it is a bit faster than DrawMultipleHUDText().
                        However, even if I only draw 4 texts using this code, the framerate on my iMac is down to 24 fps (tested in R21). Using my own code, I get 127 fps. I'll see if it can be optimised more (e.g. by making the clip map a member of MyClass so it does not have to be allocated for every draw call.
                        Frank
                        EDIT: And it gets slower in a linear way. drawing 4 texts only gives me 12 fps. So, it looked promising, and I thank you very much for the code, as it gives me some new inspiration on how to do text drawing in the viewport), but for what I need to do (drawing > 30 texts on average), it is not suitable.
                        www.frankwilleke.de
