    update User Data with Preset info
    5 Posts 2 Posters 1.0k Views 2 Watching
    • SwinnS Offline
      Swinn
      Hi, I am trying to use values from a preset to update/change a User Data field. The console prints out the correct value but the User Data field remains unchanged. Can you tell me what I am missing? Thanks.
          neon = op.GetObject()
          UD = neon.GetUserDataContainer()
          g_dirty_glass_presets = neon[c4d.ID_USERDATA,185]
          g_smudges = neon[c4d.ID_USERDATA,183]
          g_dirt = neon[c4d.ID_USERDATA,192]
          g_scratches = neon[c4d.ID_USERDATA,189]
          g_scale = neon[c4d.ID_USERDATA,193]
          if g_dirty_glass_presets == 0:
              g_scratches = 5.0
              print g_scratches
        the atomic types of Python are all immutable. So doing something like
        >>> x = my_node[c4d.ID_USER_DATA, 1]
        >>> type(x)
        <type 'int'>
        >>> x = 5
        will only change the local copy reference of that immutable type.
        If you want to copy an immutable attribute, you will have to copy from node to node. Here is an example for copying an integer from node_a to node_b only if the integer in node_a equals 0.
        if if node_a[c4d.ID_USERDATA, 1] is 0:
           node_a[c4d.ID_USERDATA, 1] = node_b[c4d.ID_USERDATA, 1]
        zipit
        • SwinnS Offline
          Swinn
          This is from another scene I made. It resets User Data by inserting values when a button is clicked on. The button then resets. This code works. Why is the other code I posted not working?
              ID_RESET_Classic_Beer = 29
              ID_RESET_Cool_Pop = 412
              ID_RESET_Dew = 413
              ID_RESET_Fridge = 414
              ID_RESET_Summer = 415
              ID_RESET_Mountain = 416
              ID_RESET_Cooler = 417
              ID_RESET_Picnic = 418
              ID_RESET_Heat_Wave = 419
              ID_RESET_Drive_in = 420
              ID_PRESET = 13
              rig = op.GetObject()
                  # reset Classic Beer
              if rig[c4d.ID_USERDATA, ID_RESET_Classic_Beer]:
                  rig[c4d.ID_USERDATA, ID_RESET_Classic_Beer] = False
                  rig[c4d.ID_USERDATA, 196] = 0       # Classic Beer MASTER Coalesce
                  rig[c4d.ID_USERDATA, 197] = 1       # Classic Beer Coalesce Amount
                  rig[c4d.ID_USERDATA, 198] = 1       # Classic Beer BIG and SMALL Random Scale
                  rig[c4d.ID_USERDATA, 199] = 3       # Classic Beer Mesh Density
                  rig[c4d.ID_USERDATA, 201] = 1       # Classic Beer BIG Drops
                  rig[c4d.ID_USERDATA, 202] = 500     # Classic Beer BIG Amount
                  rig[c4d.ID_USERDATA, 203] = 3       # Classic Beer BIG Size
                  rig[c4d.ID_USERDATA, 204] = 26085   # Classic Beer Random Seed BIG
                  rig[c4d.ID_USERDATA, 206] = 1       # Classic Beer SMALL Drops
                  rig[c4d.ID_USERDATA, 207] = 800     # Classic Beer SMALL Amount
                  rig[c4d.ID_USERDATA, 208] = 1.6     # Classic Beer SMALL Size
                  rig[c4d.ID_USERDATA, 209] = 24338   # Classic Beer Random Seed SMALL
                  rig[c4d.ID_USERDATA, 211] = 1       # Classic Beer MICRO Drops
                  rig[c4d.ID_USERDATA, 212] = 2000    # Classic Beer MICRO Amount
                  rig[c4d.ID_USERDATA, 213] = 3       # Classic Beer MICRO Size
                  rig[c4d.ID_USERDATA, 214] = .18     # Classic Beer MICRO Strength
                  rig[c4d.ID_USERDATA, 215] = 28643   # Classic Beer RANDOM Seed MICRO
                  rig[c4d.ID_USERDATA, 190] = 0       # Classic Beer MIST Off On
                  rig[c4d.ID_USERDATA, 191] = 1000    # Classic Beer MIST Amount
                  rig[c4d.ID_USERDATA, 192] = 1       # Classic Beer MIST Droplet Size
                  rig[c4d.ID_USERDATA, 193] = 12345   # Classic Beer Random Seed MIST
                  rig[c4d.ID_USERDATA, 194] = 2       # Classic Beer Random Scale MIST
          • SwinnS Offline
            Swinn
            Okay, this code works:
                g_ext = neon[c4d.ID_USERDATA,25]
                reset = neon[c4d.ID_USERDATA,229]
                if neon[c4d.ID_USERDATA,185] == 0:
                    neon[c4d.ID_USERDATA,189] = 5
            I have set neon[c4d.ID_USERDATA,189] to a float. How would I set it to a gradient? How would I set it to a 2D vector? Thanks.
              you cannot, because the data container of a BaseList2D is not dynamically typed (like Python itself), but bound to data types specified in its description. If you want to change the data type of an user data element, you will have to modify the description of that element via GetUserDataContainer and SetUserDataContainer. There is also no 2D-Vector type in Cinema, only the crosshair thing custom GUI which you can apply to a Vector description element.
              zipit
