    Python Tag not updating (The Sequel)
    7 Posts 2 Posters 1.0k Views 2 Watching
    • SwinnS Offline
      Swinn
      Further to this post:
      https://developers.maxon.net/forum/topic/12559/python-tag-not-updating
      Where to I pass the str variable in the code? I do not see the place for it. Thanks.
        Hi @Swinn could you post your code?
        • SwinnS Offline
          Swinn
          import maxon
          def message(msg_type, data):
              if msg_type == c4d.MSG_NOTIFY_EVENT:
                  event_data = data['event_data']
                  msg_id = event_data['msg_id']
                  if msg_id == c4d.MSG_DESCRIPTION_POSTSETPARAMETER:
                      desc_id = event_data['msg_data']['descid']
                      if desc_id[1].id == 2398: # The ID of the User Data
                          txt = "Swinn"
                          pythonLogger = maxon.Loggers.Python()
                          pythonLogger.Write(maxon.TARGETAUDIENCE.ALL, txt, maxon.MAXON_SOURCE_LOCATION(1), maxon.WRITEMETA.UI_SYNC_DRAW)
                          mtx =  op.GetObject().GetMg()
                          mtx.off = mtx.off + c4d.Vector(10,0,0)
                          op.GetObject().SetMg(mtx)
              obj = op.GetObject()
              # Check if we already listen for message
              if not obj.FindEventNotification(doc, op, c4d.NOTIFY_EVENT_MESSAGE):
                  obj.AddEventNotification(op, c4d.NOTIFY_EVENT_MESSAGE, 0, c4d.BaseContainer())
            Here in the latest S22 it's working as it should, and print Swinn to the console, on which version are you?
            Moreover what I was referring to is the LogerInterface.Write require a maxon.String, by convenience, if the passed data is a str (python Type) it will create on the fly a maxon.String, but if you pass another kind of data type, this will not be converted to a string even if there is a possible string representation, so you need to transform your datatype to a str the usual way is by doing str(YourData) so in our example, it will give us
            txt = c4d.Vector()
            pythonLogger.Write(maxon.TARGETAUDIENCE.ALL, str(txt), maxon.MAXON_SOURCE_LOCATION(1), maxon.WRITEMETA.UI_SYNC_DRAW)
            • SwinnS Offline
              Swinn
              I am on R20.
                Sorry, I should have spotted it earlier, this issue is solved in R21.
                So, unfortunately, I don't have any workaround for you.
                Maxime
                • SwinnS Offline
                  Swinn
                  Ah! Okay. Thanks. 🙂
